03-10-2012, 09:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | sn0wbreeze v2.9.2 Tethered Jailbreak support for 3GS/iPod Touch 3/A4 Users iOS 5.1 What is New? Added Tethered Jailbreak support for 3GS/iPod Touch 3/A4 Users on iOS 5.1 (9B176) iPhone 3GS old-bootrom users are untethered on 5.1/9B176 (as usual). Bug Fixes (Specifically with the iPad baseband and iPhone 2G). Re-added the iPhone Dev-Team's iPhone 2G permanent unlock 'BootNeuter'. http://downloads.ih8sn0w.com/sn0wbreeze-v2.9.2.zip |
The Following 5 Users Say Thank You to mohit_kripalu01 For This Useful Post: |
03-11-2012, 11:21 | #3 (permalink) |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Step 1: Open Sn0wbreeze, then click the blue arrow. Step 2: Now SnOwbreeze 2.9.2 will ask you to browse fro an IPSW, Click on “Browse” then point it to iOS 5.1 ipsw file. Step 3: After Sn0wbreeze verified your ipsw file you’ll see the below screenshot, click the blue arrow. Step 4: Select “Simple Mode” Step 5: Click yes if you wanna Hactivate your iPhone. Then Sn0wbreeze 2.9.2 will now cooks your custom pre-jailbroken IPSW file (it will take some time, don’t worry). After finishing, you will find the custom 5.1 firmware waiting for you at desktop. Step 6: Connect your iPhone to your computer Via USB, Open iTunes, Then hold the “Shift” button and click on “Restore” and point iTunes to the custom IPSW created by Sn0wbreeze 2.9.2 on your desktop. How to add Semi tethered to your iPhone 4, 3GS, iPad 1, iPod touch 4G, 3G: What’s Semi-tethered jailbreak means : The main issue of tethered jailbreak is that you need to connect your device to computer to use Redsn0w “Just Boot” tethered option every time your reboot your device. Semi-tethered jailbreak come specially to fix this issue, as it allows you reboot your device without connecting it with computer. So now you have untethered jailbreak on iOS 5. But the main issue is that 99% of jailbreak apps and tweaks won’t work at all. So what now ? Semi-tethered jailbreak is only a protection for you if your device re***** while you were away from your computer, but you will be able to use the most important functions of you iPhone until you get home and connect it with Redsn0w.Step 1: Now, open Cydia > Manage > Sources. step 2: Tap on Edit > Add and insert the following repository semitethered jailbreak | iPhone News, Apps, BigBoss, Guides & Jailbreaking Step 3: Search for SemiTether and install it then reboot your device. Step 4: Now congratulations, now you have protected your device and you will never stuck on Apple logo again all pic and matter copy paste thanks |
The Following 4 Users Say Thank You to mohit_kripalu01 For This Useful Post: |
03-12-2012, 06:43 | #6 (permalink) |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | How To Unlock iOS 5.1 On iPhone 4 / iPhone 3GS Using Ultrasn0w Fixer How To Unlock iOS 5.1 On iPhone 4 / iPhone 3GS Using Ultrasn0w Fixer Step 1: Launch Cydia and select the ‘Manage‘ tab from the tool bar at the bottom of the application. Select ‘Sources’ from the resultant list. Step 2: Tap the ‘Edit‘ option in the top right hand corner of the screen before selecting the ‘Add‘ button on the left hand side of the tool bar. Step 3: In the pop up alert view enter the repository URL which is ‘Untitled Document‘, then press ‘Add Source‘. Step 4: After the repository has refreshed and finished loading sources, tap on the repo name in the sources list which will display the Ultrasn0w Fixer utility. Step 5: Select the Fixer utility, pressing ‘Install‘ in the top right hand corner. Confirm the installation and then wait for the process to be completed. Step 6: Now that the Fixer package is complete, the current Ultrasn0w 1.2.5 software needs to be installed. Select the ‘Search’ option from the bottom of Cydia, typing in ‘Ultrasn0w‘ and hitting the ‘Search‘ button. Step 7: When the Ultrasn0w tool appears, select it from the table and then select ‘Install’ as per step 5. After the installation has been confirmed and processed, the device should be unlocked as long as it meets the hardware and baseband requirements. |
The Following 2 Users Say Thank You to mohit_kripalu01 For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
