08-13-2011, 20:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 936896 Status: Offline Thanks Meter: 14 | soldering products advice can someone tell me what products to use and where to get them off the net? I have just started learning desoldering and soldering i wanna try oon old motherboards etc I successfully managed to remove a video card chip from a motherboard using hot air gun now how do i remove the soldering on the chip and motherboard?what kind of flux gel and where to get it? where do i get those tiny soldering balls to solder back again? do i need to put something else other then those soldering balls when soldering the chip back? thank you |
08-14-2011, 21:12 | #5 (permalink) | |
Junior Member Join Date: Aug 2011
Member: 1632195 Status: Offline Thanks Meter: 0 | Quote:
I hope this helps as I'm from Canada and have not bought anything from this retailer before. | |
08-15-2011, 00:14 | #6 (permalink) |
Member: 936896 Status: Offline Thanks Meter: 14 | thank you for your advice I have aoyue soldering station? does anyone know where I can get a 1mm soldering pen(the tip extension) ? what is the flux pen used for? do I have to apply flux at all the connections ,why so? and where can i get this product? the website you provided is good but can someone tell me a site which is safe and possibly place in the uk in manchester. |
08-16-2011, 00:50 | #7 (permalink) |
Major Poster Join Date: Jan 2005 Age: 66
Member: 106942 Status: Offline Thanks Meter: 0 | For de-soldering you can use copper briad to soak up the surplus solder its sold in small roles, I use it for delcate jobs and maplins have it. Also I use a desoldering suction pen, its like a pen that you pre-load, its spring loaded you then melt the solder and place the nozzle of the pen on the solder and press the button it will then suck up the solder from the joint. try this link solder sucker | eBay But you most importantly need a soldering iron that you can control the temp on its worth the money when you are messing with delicate components. gizzburn |
Product Profile files(.pp) for Wintesla | landy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-06-2001 16:59 |
Source for all the latest unlock info and products | Buffoon | GSM Mobile Links | 0 | 03-19-2001 12:18 |
need advice on 8810 headset/power down problem | goof | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-24-2001 20:56 |
Nokia 6161 advice | jrouss | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-02-2000 10:49 |
