03-10-2017, 18:39 | #1 (permalink) |
Insane Poster Join Date: Feb 2016
Member: 2525697 Status: Offline Thanks Meter: 4 | iPhone 4 network issues |
The Following User Says Thank You to duncanzes For This Useful Post: |
04-03-2017, 09:28 | #3 (permalink) |
Junior Member Join Date: Apr 2017 Location: france
Member: 2702633 Status: Offline Thanks Meter: 1 | I had this issue aswell and i went to a shop and they started up the phone with a computor and helped me to install everything to get it working. Go to your closest mobileshop and they can prolly help you out. Good luck with it! |
The Following User Says Thank You to MobileChris For This Useful Post: |
04-09-2017, 20:15 | #4 (permalink) |
Member: 2704989 Status: Offline Thanks Meter: 4 | you need to full flash to solve IMEI problem chk on icloud statue.. using IMEI at any iphone info web if Find my iphone is : locked be sure that u have icloudand password connect your phone to ur computer and restore it from itunes * don't restore iOS devices if find my iphone statue is locked without having icloud id and password |
The Following 2 Users Say Thank You to IM_ For This Useful Post: |
05-05-2017, 13:13 | #6 (permalink) |
Member: 2710747 Status: Offline Thanks Meter: 0 | iDoctor reparation iphone Network problem is considered to be one of the most common problems that occur in smart phones. Normally there are three type of network issues such as low Signal, No Signal and signal keeps on dropping. Remove and reinsert SIM card can be simple solution for this. If the above method doesn’t work then restart your iPhone and you update your software properly. Last edited by loca|host; 05-06-2017 at 09:46. Reason: unreadable color |
