Strange problem how can I repair... My Uploaded 3GS 4.1 iPhone1, 2_4. 1_8B117_Custom_Restore_iPhone http://www.img.gem-flash.com/images/...2106402414.jpg http://www.img.gem-flash.com/images/...8654013858.jpg http://www.img.gem-flash.com/images/...6353188795.jpg Please help me I'm in trouble :( |
I did all the steps successfully Has not changed anything Is there another solution |
1. Place original APPLE 3.1.3 via iTunes to the phone (when Error in Itunes happens, kick it out of recovery with tinyUmbrella) ...then you will have Wifi again on your phone 2. Go over wifi on you phone to www.jailbreakme.com 3. When Cydia is installed, make unlock with ultrasnow. Then you will have FW 3.1.3 with BB 6.15 Maybe you can try this with FW 4.0, 4,1 , but higher versions are not supportet on jailbreakme. For my phone with works 100%. Before no IMEI, no nothing.... |
if above are not working in your case it mean there is hardware problem in your phone might be baseband proccessor is not working |
Brother this is one of the strangest thing i have ever come to know. Look out for the hardware for any fault if only your software restore to the older versions fails. |
i am also facing with this same issue. is there any solution for this? as the reception keep on placing as searching! |
costum firmware iPhone1, 2_4. 1_8B117_Custom_Restore_iPhone 3g firmvare ? |
Thank you all I bought the iPhone because of the client is not valid And the problem still can not find a solution I hope that you do not experience this problem any person Where you attempt all the above solutions No result Please help expected of any other solutions ... |
