Old 08-26-2011, 19:32   #1 (permalink)
Member: 9974
Thanks Meter: 2
iPhone not detected after restart
Hi all
So i have an 3g on 4.2.1 with latest baseband (not iPad one, not jailbroken and not unlocked)
Was all ok and after reseting it and delete all it doesn`t get recognised by any PC or/and iTunes
It`s not a PC issue as i have other iPhone working ok with no problems.
It`s not also a connector problem as i`ve changed it and still the same.
Not recognized, no "dingdong" sound, nothing
It accepts charge but no spark symbol apears on screen as if it`s not beeing charged, but it is...
Tried several cables, and several usb ports on 3 diferent computers running Windows XP (wich on all other iPhone workes fine)
The iPhone it`s now stuck on connect to iTunes for activation
Any tips would be apretiated?
Old 08-26-2011, 21:04   #2 (permalink)
Member: 9974
Thanks Meter: 2
Just tested on MAC with no luck at all
Also forgot to say, no error message apears
Old 08-26-2011, 22:36   #3 (permalink)
Member: 137489
Thanks Meter: 68
I have the same problem with one 3GS after i jailbreak but the phone said TEMPERATURE in display,any solution ?
Old 08-27-2011, 11:31   #4 (permalink)
Member: 9974
Thanks Meter: 2
Been searching for a few days and realise that we`re not alone on this. But no one have solution as far as i can tell...
Old 08-27-2011, 12:40   #5 (permalink)
Cheater -Don't Deal with him-
Member: 1587164
Thanks Meter: 39
Try To Contact Your Phone In DFU Mode
Old 08-27-2011, 13:02   #6 (permalink)
Member: 9974
Thanks Meter: 2
Done that, no luck.
Already try diferent methods with no luck
Already changed boards to a 100% working phone and still no connection
got to be a sw issue
Old 08-27-2011, 15:01   #7 (permalink)
Member: 1236325
Sonork: 100.1616831
Thanks Meter: 272
try to uninstall itunes and install latest itunes restart u'r pc and change usb cable port maybe will work ?
Old 08-27-2011, 15:28   #8 (permalink)
Member: 9974
Thanks Meter: 2
Not a pc problem as all other iPhones connects perfectly
But thanks
Old 08-27-2011, 18:00   #9 (permalink)
Shahin Hasan's Avatar
Member: 1529244
Sonork: 1720
Thanks Meter: 150
Brother,
First: Use IREB-4
Second: restore 4.1
Threed: Jelbreak 4.1 with redsn0w v9.6b6
Four: Unlock. thanks
The Following User Says Thank You to Shahin Hasan For This Useful Post:
Old 08-29-2011, 11:14   #10 (permalink)
Member: 9974
Thanks Meter: 2
Originally Posted by Shahin Hasan View Post
Brother,
First: Use IREB-4
Second: restore 4.1
Can`t thank you enought
As soon as i open iReb the iphone was instantly recognised
All ok now
Much apretiated
Old 09-14-2011, 10:40   #11 (permalink)
Member: 9974
Thanks Meter: 2
Hi Shahin Hasan
Once again the iPhone is not being recognized
It was all ok, untill i had to open it to change power button and as i disconet board from battery the same error apears on phone.
Already tryed a bunch of things with no luck
Any ideias on what to do?
i-reb is not doing the trick now..
Old 09-14-2011, 11:04   #12 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
now what is prob in ur phone not receognized or what
pls tel i will try to help u
Old 09-14-2011, 11:11   #13 (permalink)
Member: 9974
Thanks Meter: 2
Originally Posted by redevip View Post
Hi all
All as described on first post
Thanks
Old 09-14-2011, 11:18   #14 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
bro if all is working than its means 1 thing is missing so change ur cable if same than use other pc if again same than chack iphne jack ....hope it will be done
Old 09-14-2011, 11:28   #15 (permalink)
Member: 9974
Thanks Meter: 2
all that done and still the same
Seams sw problems as pc recognizes something was connected but doesn`t know it`s the iPhone
same error on every computers
already changed board to other iphone and still the same
other iphones work great on this computers
it was doing the same thing a few days back and i-reb worked, but as open it to change power button he is stuck again
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2000 22:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 0.24059 seconds with 9 queries
