04-28-2011, 08:08 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: sylhet
Member: 517801 Status: Offline Sonork: 100.1594355 Thanks Meter: 316 | unknown error (21) while restoring iPhoneunknown error (21) while restoring iPhone I have an iPhone 3GS and I am trying to upgrade to iOS 4.3.2 but it keeps giving me errors (21). I also tried using a custom firmware of 4.3.2 but that gave me the same errors (21). What can I do? help me out? |
05-01-2011, 22:18 | #4 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: matein-3
Member: 628359 Status: Offline Sonork: 100.1583762 Thanks Meter: 39 | Quote:
What can I do? help me | |
01-01-2012, 14:36 | #5 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Germany
Member: 858721 Status: Offline Thanks Meter: 8 | i got last time the same probme. i try it with with other pc and it worked! some time this problem caused by itunes. so reinstall itunes or try with other pc... |
01-01-2012, 15:20 | #6 (permalink) |
Insane Poster Join Date: Nov 2004 Age: 47
Member: 89550 Status: Offline Thanks Meter: 8 | error 21 is hardware problem and this is solution try and write the resault http://forum.gsmhosting.com/vbb/atta...2&d=1321623496 |
01-01-2012, 19:09 | #8 (permalink) |
Freak Poster Join Date: May 2009 Age: 42
Member: 1039707 Status: Offline Thanks Meter: 11 | well u must download IREB 4 1 close ut itune 2 run IREB 3 when u finish u open host file and u delete the last line 4 run itune and restore ( shift + restore ) and thats all |
01-01-2012, 19:14 | #9 (permalink) |
Member: 1039707 Status: Offline Thanks Meter: 11 | host file you will go to your windows files then system 32 > DIVERS > ETC u ull find some files the 1st one called hosts move it top ur desck then open it with bloc note go to the last line delete it or just add # in the front then save changes and move again the host file to his place and ur probleme is fixed |
01-02-2012, 07:49 | #10 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Bahawal Nagar
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | To fix iTunes error 21, you must put your iDevice into DFU mode using the following instructions: Connect your iDevice to your PC or Mac via USB cable and launch iTunes. Hold down the Home+Power button for 10 seconds. After 10 seconds, release the Power button but keep holding the Home button until iTunes detect your iPhone in recovery mode. Once your iDevice is in DFU mode, you should see nothing on its screen. It should be completely blank. |
01-02-2012, 08:04 | #11 (permalink) |
Insane Poster Join Date: Mar 2011
Member: 1526994 Status: Offline Thanks Meter: 6 | It's usually hardware damage and goes along with error 9. If you can get past the error, the iPhone will either freeze on waiting for iPhone or shut off. Try with another computer to make sure it's not PC-related. |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
HEX for CLIP to restore Factory Defaults | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2000 15:59 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
