10-05-2012, 17:01 | #1 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1820737 Status: Offline Thanks Meter: 0 | A way to update iPhone 4 to iOS 6 without updating the baseband [succeeded] So I tried and figured a method out. iTunes updates the firmware(baseband) after updating the system, so we can prevent iTunes from updating baseband after the system is updated. You need to do the following x steps: 1.backup your 5.x shsh blobs 2.run redsn0w0.9.13dev4, select Extra->Even More->DFU IPSW to make a "DFU IPSW" of 6.0 3.add ".zip" to the file, unzip, delete all file that the name contains "04.12.02" in folder "firmware" 4.create a zip file and rename back to .ipsw 5.boot the device to DFU mode, open iTunes, restore iPhone using the new ipsw 6.you will receive an error during the process, and your phone will enter "Recovery Mode" 7.enter DFU mode again, open redsn0w 0.9.13dev4, click "Select IPSW", select the new IPSW, and click on "Recovery Fix" 8.reboot the phone and you will enter iOS6. If you use ultrasn0w to unlock or need to put activation ticket, etc. You must jailbreak it and you need to connect the phone every time it reboots. This a screenshot of my phone after updated to iOS6. IMG_0006 1.jpg I posted this on a Chinese forum and someone got his phone successfully updated: 198807_29c913494448932e9edf6361caa26.jpg198807_419c134944489852078d89a49377a.png You can reach me @fatlyz at twitter.com |
