05-06-2014, 07:27 | #17 (permalink) |
Junior Member Join Date: Aug 2010 Location: London, United Kingdom Age: 40
Member: 1361021 Status: Offline Thanks Meter: 24 | changing chips in the iphone is no easy task, it requires specialized soldering tools, consumables and a very experienced BGA technician but the hardware theory is sound, it worked before, when unlocking iphones took gevey sims and ultrasn0w, but for the majority, hardware chip swapping was the only solution |
07-09-2015, 09:32 | #19 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | i also have 2 iphone 4s..one is blacklisted but still in good shape and the other is water damaged..the water damaged is unlocked not blacklisted and never been link to an icloud acount..what chip should i swap to make its imei transfered to other one that is blacklisted? |
07-11-2015, 08:26 | #20 (permalink) | |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Quote:
but ! the only one who invented or made this 1st in world was Dejan from serbia and now he is dead, ! and how i can know he managed to change up to iphone 4 now are some chinese which do, but they also support up to iphone 4, bcz after baseband chip is replace i thing need write new imei so , the tools support only iphone 4, others cpu not exploitable or patchable | |
07-15-2015, 09:37 | #22 (permalink) | |
http://forum.gsmhosting.com/vbb/f601...jevic-1931308/ | |
07-15-2015, 13:09 | #23 (permalink) | |
Member: 1361021 Status: Offline Thanks Meter: 24 | Quote:
Check out this video on how it is done, heat the IC's thoroughly to insure you don't get lifted pads from the logic board, clean and reball the replacement IC's and use the proper flux, I would recommend using the leaded solder instead of lead free, it has a lower melting point. Last edited by pkkilleru; 07-15-2015 at 13:17. | |
