09-13-2010, 15:22 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: tirana
Member: 1254195 Status: Offline Sonork: 5454 Thanks Meter: 119 | Why Cydia save only 4.1 SHSH ? B.R |
09-13-2010, 16:25 | #5 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | give it a try and tell us put ur phone in recovery and then connect it to tinyumbrella and then select advance option and select 4.0.1 select 3Gs and cydia then click save my shsh after this press kick out try and post the result coz i m out for 5 days from work now will join u tomorrow downgrading is some thing different coz if some one already update it to new modem firmware then there is no solution except u have factory unlocked phone |
09-13-2010, 16:53 | #6 (permalink) |
Freak Poster Join Date: May 2010
Member: 1298064 Status: Offline Thanks Meter: 21 | It doesn't matter you are jailbroken or not, doesn't even mean that when you are jailbroken it will automatically saved your shsh blobs...LOL...I just test umbrella now it's working from 3xxx to 4.1. The question you need to answer is Did you saved your blobs when apple is signing 4.0.1, by the time you jailbreak your device like make my life easier? or did you see you have shsh blobs in cydia pages in your iphone? With regards to iphone have save shsh blobs.. sure can downgrade to 4.0 or 4.0.1 using restore... CHEERS!! |
09-13-2010, 17:37 | #7 (permalink) | |
Member: 1254195 Status: Offline Sonork: 5454 Thanks Meter: 119 | Quote:
B.R | |
09-14-2010, 03:34 | #9 (permalink) |
Member: 1298064 Status: Offline Thanks Meter: 21 | OHHH SORRY!! not only you have the same problem, So it's not cydia server error since your device is damaged before the confirmation of the shsh blobs...no other solution go for 4.1 then wait... CHEEERS!!! |
09-14-2010, 07:15 | #12 (permalink) |
Insane Poster Join Date: Jul 2004 Location: Zimbabwe Age: 43
Member: 74812 Status: Offline Thanks Meter: 13 | TinyUmbrella with 4.1 Support UPDATE: It appears Apple is not signing 4.0.2 SHSH requests anymore. As a result I've updated TinyUmbrella to 4.1.4 which will default to grab the 4.1 SHSH for iDevices (3.2.2 for iPads). I put my money where my ***** is. I tested my code on my own iPhone 4 and was able to update to 4.1 without touching my baseband. The only doctoring I did was removing my private info. The newest version of TinyUmbrella will have an added side-benefit of allowing you to update to 4.1 without the fear of baseband update. Of course, in order to downgrade back to 4.0.x you need to have your SHSH saved on Cydia or locally. Have fun I've also seen a TON of questions about how to update from 4.0.x to 4.1 WITHOUT updating your baseband. I'll give you a quick rundown of how to do it. * Get the latest TinyUmbrella (4.1.3) * READ THE README TinyUmbrella README NOW Yes. You Read it. * Run TinyUmbrella. * Start TSS Server * Open iTunes * Restore 4.1 (NOT UPDATE) Yes this requires you to download 4.1 Here * Let iTunes error with 1004 error (baseband update failed - we want this ) * Kick Device Out of Recovery * \o/ -- You are now on 4.1 with 1.59.00 baseband! The Firmware Umbrella |
09-14-2010, 07:17 | #13 (permalink) |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
