Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
07-05-2008, 17:03 | #155 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Chinese Section Age: 37
Member: 594884 Status: Offline Thanks Meter: 1,553 | Sony Ericsson 18166 Pinouts Welcome to uses Xintel box / Vepro Box GuangZhou VicEasy Http://www.VE100.com www.xintel.com.cn find available comport... Comport:COM5 COM5 connect to box. box ver:V2.2 datetime:Aug 08 2007 box SN:- - - - - verify code:- - - - custom name:GZHW sale date:2007-09-16 Connect to VE-Dongles! VE-Dongles SN:- - - - - - - _ - - - -- - - - VE-Dongles Ver:V2.3 Datetime:2007-07 welcome to use xintel intelligent box. ------------------- please keep down power key. until spy success!(press F4 break.) GND:8 spy and analyse define ->---- MTKchips connect to phone. spy define success!RXD:7 TXD:5 ------------------- define set success!RXD:7 TXD:5 hint:run outside soft , please remove datacable and vccout clip. spy complete. ------------------- please keep down power key. until spy success!(press F4 break.) GND:8 spy and analyse define ->---- MTKchips connect to phone. spy define success!RXD:7 TXD:5 ------------------- define set success!RXD:7 TXD:5 hint:run outside soft , please remove datacable and vccout clip. spy complete. ------------------- please keep down power key. until spy success!(press F4 break.) GND:8 spy and analyse define ->----MTKchips connect to phone. spy define success!RXD:7 TXD:5 ------------------- define set success!RXD:7 TXD:5 hint:run outside soft , please remove datacable and vccout clip. spy complete. hint:double line datacable, normal mode use fast spy . ------------------- please keep down power key. until spy success!(press F4 break.) GND:2 3 VCC:10 spy and analyse define ->(auto double lines.)---------*..... ......... MTKchips connect to phone. spy define success!RXD:7, TXD:8 please return 'set define' page,press 'set define' button. ------------------- define set success!RXD:7 TXD:8 >>hint:run outside soft , please remove datacable and vccout clip. PL2303 USB To COM5 Found VE-Dongles ... connect to VE-Dongles! Ve-Dongles sn:- - - - - - - - _ - - - - - - - - VE-Dongles Ver.:V2.3 Datetime:2007-07 VT-Dongles data success! ---------------- open comport:COM5 please turnon your phone ,until connect success(press F4 Abort). connect to Phone. CPU model :6226 ( HW_VER: 8A02 ) download Boot ... boot File Ver.:04.02 NOR flash model :[SPANSION] S71PL127N NOR flash size:01000000 (16.0M) NOR flash ID code :0001227E (22202200) [86] Int.RAM size:00047000 (0.284M) Ext.RAM size:00400000 (4.0M) Bootloader in [NOR] flash Read flash information operation done! Auto format address ??00E00000 operation len??00200000 NOR (auto) format operation ... >>operation done. |
The Following User Says Thank You to .::skybird::. For This Useful Post: |
07-09-2008, 09:27 | #165 (permalink) |
Member: 594884 Status: Offline Thanks Meter: 1,553 | Please, follow instruction exactly like described below In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model: 1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location) 2. find Charge pins (it's optional step, just to save your time during future research) 3. find +Battery pins (it's optional step, just to save your time during future research) 4. connect cable Gnd to phone Gnd 5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone 6. if flash read procedure can start this means that pinout found Ok and you can make other operations Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "All cable's pinouts for chines phones" wrong pinout for "Chinese models" it's good idea to find correct pinout according to above instruction and send new pinout information with full text from phone back label here in this thread. Best regards |
The Following 3 Users Say Thank You to .::skybird::. For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f457/all-cables-pinouts-chines-mobiles-511116/ | ||||
Posted By | For | Type | Date | |
All cable's pinouts for chines Mobiles | This thread | Trackback: | 08-28-2011 20:26 |
Spiderman Always The Best For Chines Mobile | M@TRIX | Main Sales Section | 0 | 10-13-2009 20:21 |
Which Is the best tool for chines mobiles | mobilecitycbk | Chinese Models & Cloned Phones | 2 | 01-14-2009 16:12 |
need pinout for chines y690 1x18 pin jeack | sonumobilewala | Infinity-Box | 1 | 06-04-2008 21:40 |
Need for Service and User Manuals for Chinees mobiles | Swedafone | Infinity-Box | 1 | 01-01-2008 13:29 |
plz team help me for chines mobile | MNGASHNET | Infinity-Box | 9 | 05-28-2007 22:24 |
