ALL CHINESE MOBILE SOFTWARE AND HARDWARE 100% solution maximus ex60,sprint7700,nckia n95,nokla,cgc,mpeg4,nokia6300, and all mtk chip chinese mobile problem! send post and take easy solution. |
Hi, Is there any software available for UFO 933 Digital Mobile Cheers!! |
Find Rx .tx Signles easyyy Find Rx .tx Signles easyyy HOW TO FIND RX .TX SIGNLES . It is tasted and also you can test it. 1 step is, we need to find GND from phone. 2 step is, we should power on phone (operation with dead phone: phone must be 100% dead by software)and take multimater put it to voltage. 3 multimeter (-) line put it GND and with (+) line check each connectors , and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v (it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v) This way is too easy and you will save a more time. For example! You have got new brand China miracle phone with USB cable. It has got 12 pin. You must find (Infinity team give good Idea 1.2.3 punkts): 1) GND usually it has got 2 GND. (now we have got 10 pins) 2) We will uncheck USB + and USB- (VSS) just with checking by USB cable (now we have 8 pins) 3) By USB cable we also uncheck V bat+, ac adaptor + polarization (now we have 7 pins) 4) Now from this 7 pins you will find 1 or 3 not used pins (last operation we have 3 or 6 pins to find Rx Tx signals) 5) Now at last operation you should use good multimeter just to find Rx Tx with 1.7v-2.7v or 1.8v-2.8v 6) WHEN PHONE IS POWERD OFF TX AND GND WITH MULTIMETER MAKING BEEEEEP (DIOD TEST OPERATION), WHEN PHONE POWERED ON IT WILL SHOW LIKE DIOD RESISTANS 600-700 OHM BETWIN TX AND GND. I think I have give for every body more information’s. Just try to find. If you find 2-3 phone signals and you will be profi mobile Tx and Rx signals finder. Some times you will not find with this method some phones, but why we have forum? I'm not saying it is 100% solution but I'm saying it is TESTED solution. I'll make some guide or FAQ by pic. if I have a free time! |
@gopalhot you are giving attachment link to other site which need user and pass its against forum rules if you have somthing then post here....other wise stop posting other forum direct link |
How can one flashes Nokia 1200 with UFS3 i know call me use old ufs it is pasebal |
Post Here All China Phone Driver http://file.hit2hosting.com/download.php?id=6427E9F51 http://rapidshare.com/files/10525119...llection_1.rar Here Some Drivers MTK_DRIVER MT6227__Driver Winbond_CPU_Driver VIA_CPU_Driver Philips_CPU_Driver SpreadTrum_CPU_Driver |
Tv Mobile Avi Video Solution 100% Workin ~ P90 TV MOBILE AVI VIDEO SOLUTION 100% WORKIN ~ here is setting use total video converter 3.10 1.audio ch**** single 2.audio codec ; pcm16le sample rate; custem 8000 bitrate 64 video setings video codec mjpeg frame rate 15 bitrate custen 1600 video resize as set 208x 176 or 176x 144 |
Hey, Why my post has got deleted?? |
first try to find what cpu based phone u have. then try to find sw and pinout. br. |
hi everybody i am looking for software for read firmware for spreadtone based mobile phone (i think it is spreadtone processor cause in the bluetooth menu the name of phone is "spreadtone z95" the model of phone is BI t200+) can you tell me the name for the program or a download link? regard |
i need info about china nokla 5310 bad software mt chip 6225 |
got 1000% working solution trow them in garbage and buy a real phone :rolleyes: |
hello so please i need help. i have an chinese iPhone called "GSM Cellular Telephone with Bluetooth and two dual-sim and 4Go" model number A1203 and FCC ID: BCGA1203" designed by apple in california assembled in china. when i link it to my computer i should shut it off to open its storage folder (G,H) but when i connect it when it was "on" windows xp cannot reconise it so please give me an driver or anything to do to connect it when it is "on" to my computer and wanna know too if i can activate and synchronise it with itunes. thank you very very much. |
hi, I'm looking for tv mobile V918 firmware anyone can help with 2 sim and dual cpu mt6205. Thank's anyway. |
thanks , but how the way find USB+ and USB- , I have'n USB cable !!!! |
