BAD CONTACT CHARGER - N95 China phone help me please for my problem I'm a newbie. what I'm gonna do? :confused::(:confused: |
can anybody help me I owe you :( please some one help with my problem |
bro this is 100% charger problem just check ur charger and post result |
i've already tried to use different chargers but still the "BAD CONTACT THING" still pop-out... i really need help... BADLY |
rehot the CPU , if not ok replace the CPU. |
by the way sir thanks for your kindness.. is there any way to resolve my problem?? :( |
ok sir many thanks! ^_^ |
china 95 bad contact charger Brother just change your charger your prob will b solved your set i ok;) |
yes and in other is the soft prob use sx4 and write pm |
you can try this : Re-Heat the PCB carefully and test again, someone put another solution some time ago and works for many models, get the ( - ) negative from the charge and trace a jumper to the negative of the vibrator or GND .... test please! I hope this can help you |
Brother i think ur original charger is bad. Now u try with market charger. If u have old charger open its charging base see what pin + and - now connect in market charger as like shown original. ur problem solve. |
MAKING OF CHARGER or bad contact FOR CHINESE PHONES THIS MAIN PROBLEM IS WHEN U CHANGE UR CHARGER. IN ANY CHARGER OPEN UR CHARGER'S CHARGING CONNECTOR THEN REMOVE THE WIRES FROM CONNECTOR. RED,BLACK,GREEN,WHITE REMOVE RED & BLACK WIRE. CONNECT CHARGER WITH PHONE REMOVE BATTERY SEE - & + OF PHONE CHECK NEGATIVE CONTINUTY WITH MULTIMETER TO THE CHARGER CONNECTOR POINTS SOLDER BLACK WIRE TO NEGATIVE TRACED SOMETIMES IN SOME SETS POSITIVE IS ALSO GIVING CONTINUTY U CAN ATTACH RED WIRE. THE VOLTAGE IS OK BUT IT WILL NOT DISPLAY CHARGING THEN U HAVE TO TEST BY INSERTING BATTERY TO THE PHONE BY ANY WIRE OR TWIZER CONNECT ONE SIDE TO RED WIRE CONNECTED TO THE POINT THEN SHORT OTHERPINS ONE BY ONE BY THIS WIRE.UR PROBLEM IS SOLVED IN BAD CONTACT CHARGER PROB. U JUST HAVE TO TEST RED WIRE TO OTHER POINTS. I TRIED THIS MANY TIMES . |
