CECT I9 - no sound during calls Hi, I just got a new CECT I9 and there is no sound during a call. This is both on SIM1 and SIM2. If I plug in the headphones or turn on the speakerphone then the sound is there. I have reset to factory defaults and turned volume up to max. Any other ideas ? Thanks. John |
... I guess the handset is broken ? ... OK, I guess this is a hardware fault with the handset and I should return it as faulty ??? |
Try to set restore factory setting......... May be u r problem will be solve. If not try to format the phone. Post result. |
your having the same issue as I have, but unfortunately nobody replied to me. If you found any solution i would be thankfull to know what you done. Regards. |
