Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 08-06-2008, 12:50   #1 (permalink)
Member: 474407
Thanks Meter: 12
cect v7 set English language problem
i have cect v7 ,i use *#001#,*#0000#,*#0044# this all code not working plzzzz help
Old 08-06-2008, 12:53   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,051
Originally Posted by pratik_1111 View Post
i Have Cect V7 ,i Use *#001#,*#0000#,*#0044# This All Code Not Working Plzzzz Help
First Try Format Your Set, Then Change Langauge
Old 08-06-2008, 13:03   #3 (permalink)
Member: 474407
Thanks Meter: 12
i format then i use this code but same problem
Old 08-06-2008, 13:07   #4 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,051
TRY THIS CODE , MANY CODE & PINOUT HEAR:-
CHINA MOBILE CODES AND PINOUTS
CHINESE MODELS
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
Motorola-A1200
Cect-C600
keyboard top, connector_1x8_mini
6: Rx
7: Tx
8: Gnd
Samsung-E712D
2: Rx
3: Tx
8: Gnd
GStar-GM128
Samsung-E730+
keyboard top
1.........24
1: +Vcc
2: +Vcc
3: +Bat
4: +Bat
6: Tx
8: Rx
11: Gnd
17: Gnd
20: Gnd
Cect Q300
keyboard top
1.........18
Samsung-X810+
Samsung-D500i
Samsung-D600i
keyboard top
1.........18
3: Gnd
7: Rx
9: Tx
Nokia-N70C
TIANYU A699 ???
keyboard top
1.........18
1: +Vcc
2: +Vcc
4: Tx
5: Rx
8: Gnd
11: Gnd
Nokia-G6-Power-MPEG4
connector_2x6_mini
1:
2:
3:
4:
5:
6: Gnd ??
7:
8:
9:
10:
11:
12: Gnd ??
Cect-S560
Cect-Q618
Nokia-N73
Nokia-N83
Nokia-N95
Nokia-N730
connector_2x6_mini
1:
2: Vcc
3: Vcc
4: USB D+
5: USB D-
6: Rx
7: Tx
8: Gnd
9: HF ear
10: HF ear
11: HF mic
Smarj-S70: points under battery near sim holder
ANTENNA
1 2 3 4 5
1: Rx
2: Tx
3: Gnd
GStart-GM238: points under battery near MMC
ANTENNA
1 2 3 4 5
1: Phone Rx
2: Phone Tx
3: Gnd
Nokia-8800i: points under battery near sim holder
ANTENNA
1 2 3 4
1: Rx
2: Tx
4: Gnd
Samsung-D900
Samsung-E900
keyboard top
1.........18
4: Rx
5: Gnd
9: Tx
17: +Charge
Samsung-D820
Nokia-N85
Nokia-6300
18 pin
Cect-N168
Nokia-N800
A950
keyboard top, connector_1x12_mini
5: Gnd
6: Tx
7: Rx
Samsung-D820
Nokia-N77i
Nokia-N88
Cect-C600
Camry-V138
Everfo-E863
1: Gnd
7: Tx
8: Rx
Nokia-N95 slider
1: Gnd
6: Tx
7: Rx
Nokia-N95 slider
keyboard top, connector_2x6_mini
1: Rx
2: Tx
4: Gnd
8: VBat
12: Gnd
Cect-T689
Nokia-N99
6: Tx
7: Rx
12: Gnd
Nokia-3280
1.........12
7: Rx
8: Tx
9: Gnd
GStar-G2
GStar-GM208
GStar-GM238
GStar-GM308
GStar-GM508
GStar-GM608
GStar-GM618
Nokia-8800i
Samsung-E760
Samsung-E730C
connector_2x6_mini
1: +Vcc
2:
3: Gnd
4: Rx
5: USB D-
6: Gnd
7: +Vcc
8:
9:
10:
11: Tx
12: USB D+
GStar-GM328
Samsung-D900
connector_2x6_mini
1: HF ear
2: Gnd
3: +Vcc
4:
5: Tx
6: USB D-
7: HF ear
8: HF mic
9: +Vcc
10: +Battery
11: Rx
12: USB D+
Nokia-N95 (T98)
connector_2x6_mini
1: Tx
2: Rx
6: Gnd
5: connect to pin 12
12: connect to pin-5
Nokia-N95
keyboard top
1.........18
8: Gnd
11: Gnd
13: Rx (RJ-45 pin-2)
14: Tx (RJ-45 pin-3)
Nokia-N95-PDA
keyboard top
1.........18
1: Gnd
2: Gnd
7: Rx
9: Tx
Cect-M1818
connector_2x7_mini
7: Tx
8: Rx
10: Gnd
Cect-N1818
connector_2x6_mini
3: Gnd
9: Rx
10: Tx
Cect-N1818
Cect-M901
connector_2x6_mini
3: Rx
5: Gnd
10: Tx
Cect-Y809
connector_2x6_mini
4: Tx
9: Rx
12: Gnd
L7
connector_2x6_mini
1: Gnd
6: Rx
7: Tx
GStar-GM108
KEYBOARD TOP
1.........24
6: Tx
8: Rx
11: Gnd
Motorola mpeg4 v3+
keyboard up
1........18
10: Gnd
13: Rx
14: Tx
17: +Charge
18: +Battery
Cect-P168-9900
______________
+B _. .
Tx__. . ._Gnd
Rx__.
_________________
1. for flash/unlock/reset you must use only 3 wires: Rx, Tx, Gnd
2. other pins description (f.e. +v, USB etc.) only for your reference (f.e. if you need to build your own charger)
phone bottom connector_2x6_mini
__________________
/ 1 2 3 4 5 6 \
| 7 8 9 10 11 12 |
phone bottom connector_2x7_mini
_____________________
/ 1 2 3 4 5 6 7 \
| 8 9 10 11 12 13 14 |
phone bottom connector_2x5_mini
_______________
/ 1 2 3 4 5 \
| 6 7 8 9 10 |
phone bottom connector_1x8_mini
_________________
/ 1 2 3 4 5 6 7 8 \
phone bottom connector_1x12_mini
___________________________
/ 1 2 3 4 5 6 7 8 9 10 11 12\
Nokia-N288
keyboard top
1..........8
1: Vcc
4: Gnd
7: Tx (RJ45 pin-2)
8: Rx (RJ45 pin-3)
Nokia-N92
keyboard top
1.........18
1: Gnd
2: Gnd
7: Rx
9: Tx
Nokia-6300i
keyboard top
1..........8
1: Vcc
6: Tx
7: Rx
8: Gnd
Nokia-N73
connector: the same as original Nokia
keyboard top
1.........13
2: Rx
3: Tx
7: Gnd
8: Gnd
10: Gnd
13: Gnd
Samsung-A838
Samsung-A99
keyboard top
1.........10
2: Tx (RJ45 pin 3)
3: Rx (RJ45 pin 2)
7: +power
Gnd: take from pcb
m-448 gsm mpeg 4 dual simcard (simtray under ringer)
connector_2x6_mini
3: Rx
5: Gnd
10: Tx
Nokia-N94s 2simcard phone with big LCD
connector_2x5_mini
3: Gnd
8: Phone Tx
9: Phone Rx
Nokia-N95i-Bluetooth-PDA
keyboard top
1.........18
1: Gnd
2: Gnd
13: Gnd
4: Rx
5: Tx
Motorola-L7+
keyboard top
1.........18
1: Gnd
11: Tx
12: Rx
M660
connector_1x8_mini
4: Gnd
5: Tx
8: Rx
Nokia-8030
keyboard top
1.........18
4: +V
5: +V
10: Tx
12: Rx
17: Gnd
18: Gnd
MP4-K18-PDA
connector_1x8_mini
3: Rx
4: Tx
5: Gnd
ZT-6618
ZTC-ZT6618
Xingtai-338
connector_2x5_mini
10: Gnd
4: D-
6: D+
2: +5V
ZT-6618-PDA-2sim
connector_1x8_mini
3: Rx
4: Tx
5: Gnd
Huayu-K888
16 = rx red
17+18 = gnd
15 = tx white
Bird: connector 18 pins
keyboard top
1.........18
3: Gnd
12: Rx
13: Tx
Bird: connector_2x5_mini
keyboard top
1..........5
1: Gnd
3: Rx
4: Tx
TCL-M580
connector 8 pins
keyboard top
1..........8
3: Rx
4: Tx
5: Gnd
TCL: connector_2x5_mini
4: Rx
5: Gnd
6: Tx
TCL-U80
test points under battery
1 2 3
4 5 6 7
5: Rx
6: Gnd
7: Tx
TCL-V6
keyboard top
1.........18
8: Gnd
13: Rx
14: Tx
TCL-V18
keyboard top
1.........18
15: Rx
16: Tx
18: Gnd
Porsche-Cayenne
connector_2x6_mini
1: Gnd
2: Rx
7: Gnd
8: Tx
MPEG4-A968
0---
0---vbat
0---tx
0---rx simtray here
0---gnd
Nokia-N95(T99) 2 sim
connector_2x5_mini
1: +V
4: phone Rx (RJ45 pin 2)
5: phone Tx (RJ45 pin 3)
6: Gnd
10: connect to phone pin-1
Swatch-Mobile-M300
connector_2x5_mini
--- unlock/flash ---
1+6: Gnd
7: Rx
8: Tx
5+10: +5v
--- usb data cable ---
1+6: Gnd
9: white usb
4: green usb
5+10: +5v
BMW-A8
connector 2x7
6-Gnd
5-vpp
4-Rx
9-Tx
Version info *#43*#
V666
connector 2x7
Motorola-K1
17: Rx
18: Tx
19: Gnd
Nokia-V8-slim
connector 2x7
MPEG4-touchscreen-PDA
keyboard top
1.........18
3: Tx
4: Rx
9: Gnd
10: Gnd
17: Gnd
18: Gnd
Nokia-5300
Nokia-3250
Nokia-6280 slider
keyboard top
1.........18
8: Gnd
11: Gnd
2GSM-2sim
keyboard top
1.........18
1: Gnd
3: Gnd
13: Tx
14: Rx
Nokia-N95s
Nokia-N95-PDA
Cect-P168
connector_2x5_mini
4: Phone Rx (RJ45 pin 2)
5: Phone Tx (RJ45 pin 3)
6: Gnd
Nokia-N96i
connector_2x5_mini
1: Tx
2: Rx
6: Gnd
5: connect to phone pin-10
10: connect to phone pin-5
GStar-GM209
GStar-G851
connector_2x7_mini
3: Gnd
6: Tx
13:Rx
GStar-GM809
connector_2x7_mini
2: Gnd
11: +bat
12: Rx
5: Tx
Cect-V6
Vertu
Veptu
connector_2x6_mini
1: Gnd
2: Rx
7: Gnd
8: Tx
Cect-N81
keyboard top
1.........18
3: Gnd
7: Gnd
10: Gnd
12: Gnd
14: Gnd
Malata-M696
keyboard top
1.........18
2: Gnd
3: Gnd
10: VBat
18: VCharge
Cect-U8800
Sony-Ericsson-K800
Nokia-6700i
keyboard top
1.........18
1: Gnd
9: Tx
10: Rx
12: Gnd
Cect-N1000
Cect-S500 O2 mini 3D
Vertu-8088
Veptu-8088
Narnia-8088
Xunchi-138
O2-S500
1:Vcc
2:
3:V changer
4:USB
5:USB
6:Rx
7:Tx
8:Gnd
Nokia-N73 (new release, PDA screen big than old model)
Nokia-N75 small
Cect-V668
Pocket_PC-1688-2sim
1: Gnd
2: Tx
3: Rx
4: USB D-
5: USB D+
6: +Vcc
7: +Vcc
The Following User Says Thank You to debmobile For This Useful Post:
Old 08-06-2008, 13:42   #5 (permalink)
Member: 474407
Thanks Meter: 12
no use i try all code
Old 08-06-2008, 14:21   #6 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,949
just flash your phone with new flash file same version. but don't forget to backup your current flash file before flash.
Old 08-06-2008, 21:04   #7 (permalink)
Member: 440163
Thanks Meter: 2,452
Are you sure your phone have english language? The best way for you is flashing your set with same original version, but never forget make fully backup before makeing any action.
B.R
Samsung i780 need how set english language Unicom UST Pro II 0 11-19-2009 14:48
Samsung i780 need how set english language Unicom HTC & Smartphones ( WM Without Touch) 0 11-19-2009 14:12
LG U8330 after Downgrade How to set in english Language? irish_4 LG 1 06-21-2008 14:25
plz tell me hw to set english language for sagem myx6-2 sachin_udai ARM9 BASED M62 / M62+ 1 02-29-2008 16:02
Cect U8800(11) set in English intervix HTC & PDA WM( With Touchscreen) 0 11-09-2007 10:25
Page generated in 0.33471 seconds with 8 queries
