Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
02-26-2010, 00:25 | #1 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1237143 Status: Offline Thanks Meter: 0 | cesim V800 problem! I am an Italian boy and I had a gift the CESIM V800. The phone has the following problem: when I connect the CESIM V800 via the USB cable (the one present in the box) to my laptop with Win XP SP3, the cell displays the image of the battery charger, then if I try to turn on the phone, it seems the image of the apple and immediately after the display goes completely dark (NB this problem occurs even if the phone is not 'connected to the notebook). At this point, if you try to touch the screen, it lights up blue for less than 1 second and immediately after this process the screen returns to black out completely. I tried to do some research on the problem but have not found anything; I followed the following post "China MTK Based Phones briefing" to try to flash the phone, but from the post above is written that I can't run to the flash with the supplied cable (USB Data Cable). Now, my question is: What should I do? 1) buy some cable to flash the cell (if yes, which?) 2) send it in for service (if yes, where?) 3) the phone is broken. I look even a your answer. P.S.: Sorry, for my bad English. |
02-26-2010, 23:32 | #2 (permalink) |
Member: 1237143 Status: Offline Thanks Meter: 0 | connect phone with Linux, I found more information: usb 1-3: new full speed USB device using uhci_hcd and address 7 usb 1-3: New USB device found, idVendor = 0e8d, idProduct = 0002 usb 1-3: New USB device strings: Mfr = 2, Product = 3, SerialNumber = 4 usb 1-3: Product: MT6235 usb 1-3: Manufacturer: MediaTek Inc usb 1-3: SerialNumber: 317509428611220 usb 1-3: configuration # 1 chosen from 1 choice scsi9: SCSI emulation for USB Mass Storage Devices usb-storage: device found at 7 usb-storage: waiting for device to settle before scanning usb-storage: device scan complete usb 1-3: reset high speed USB device using uhci_hcd and address 7 scsi 9:0:0:0: Direct-Access Mediatek Flash Disk 6235 PQ: 0 ANSI: 0 CCS scsi 9:0:0:1: Direct-Access Mediatek Flash Disk 6235 PQ: 0 ANSI: 0 CCS sd 9:0:0:0: Attached scsi generic sg2 type 0 sd 9:0:0:1: Attached scsi generic sg3 type 0 sd 9:0:0:0: [sdb] 15949824 512-byte logical blocks: (8.16 GB/7.60 MiB) sd 9:0:0:0: [sdb] Write Protect is off sd 9:0:0:0: [sdb] Mode Sense: 03 00 00 00 sd 9:0:0:0: [sdb] Assuming drive cache: write through sd 9:0:0:1: [sdc] 62272 512-byte logical blocks: (31.8 MB/30.4 MiB) sd 9:0:0:1: [sdc] Write Protect is off sd 9:0:0:1: [sdc] Mode Sense: 03 00 00 00 sd 9:0:0:1: [sdc] Assuming drive cache: write through sd 9:0:0:0: [sdb] Assuming drive cache: write through sdb: sdb1 sd 9:0:0:1: [sdc] Assuming drive cache: write through TDI sdc1 sdc2 sd 9:0:0:0: [sdb] Assuming drive cache: write through sd 9:0:0:0: [sdb] Attached SCSI removable disk sd 9:0:0:1: [sdc] Assuming drive cache: write through sd 9:0:0:1: [sdc] Attached SCSI removable disk After this, the computer mount three partitions, containing a set of directories and files. In my opinion looks like a boot problem but I am not fully sure. Thanks in advance and hope someone can answer me. |
02-28-2010, 10:16 | #4 (permalink) |
Member: 1237143 Status: Offline Thanks Meter: 0 | Actually it seems easier to find a cable to run the flash, which find a service center. I read that there are these boxes (Infinity, Spiderman), but not performing repairs on phones I think it's an unnecessary expense (200 ~ 300 euros). I recently saw the following post, which explains how to create a cable to run the flash of the phones Chinese http://forum.gsmhosting.com/vbb/showthread.php?t=922583 http://forum.gsmhosting.com/vbb/showthread.php?t=574212 Thanks to all. |
CESIM V800 touch problems | nina83 | Chinese Models & Cloned Phones | 9 | 03-25-2010 18:33 |
cesim v800 applications | TOMMY1977 | Chinese Models & Cloned Phones | 0 | 06-21-2009 13:04 |
cesim v800 | linterna1 | Infinity-Box | 6 | 06-18-2009 13:38 |
Cesim v800 | TOMMY1977 | Chinese Models & Cloned Phones | 0 | 06-16-2009 13:47 |
Cesim V800 Dual SIM Card Phone with Analog TV & Bluetooth | IPMART | ipmart WebShop | 0 | 02-06-2009 09:40 |
