Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 07-14-2013, 04:19   #1 (permalink)
Member: 1844155
Sonork: NONE
Thanks Meter: 42
Cherry mobile flare deadboot solution
Solution For Deadboot
Download first this Files bago tayu mag simula
QPST 2.7 build 399 -
MediaFire - Online Space for your documents, photos, videos, and music.
JB drivers -
JB_pcdrivers.rar
Jelly Bean BP Firmware
BP_JB_Firmware.rar
WARNING : Supported ito sa mga flare na nadedetect pa ng Pc if hndi ito ma detect sa pc dont do this anymore
Install QPTS (alam ko pamilyar kayo jn.. ginagamit yan sa mga broadband stick..)
install lahat ng drivers para walang aberya
Install drivers
1. Connect deadboot flare to PC / Laptop.
2. Go to device manager, expand PORTS (COM & LPT). Check if there is an item called Qualcomm HSUSB QDLOADER 9008. If the item is there, you are done with driver install. If it does not exist, proceed to step3.
3. If there is no item under PORTS (COM & LPT), check device manager under OTHER DEVICES > Unknown Device
4. Double click UNKNOWN DEVICE > UPDATE DRIVER > BROWSE MY COMPUTER > browse to the folder where you saved extracted the ICS / JB drivers. It will install the driver, if it prompts for unsigned drivers, press INSTALL ANYWAY.
5. It should now be listed under COM PORTS > Qualcomm HSUSB QDLOADER 9008.
Run QPST and reprogram EMMC (dito tayu mag sisimula)
1. Run EMMC SOFTWARE DOWNLOAD.
2. Press BROWSE, it will detect your phone. Look for the PHONE TAB that says DOWNLOAD. Press OK.
3. Put check mark on PROGRAM BOOTLOADERS, PROGRAM MMC DEVICE, TRUSTED.
4. Under FLASH PROGRAMMER FILENAME, enter MPRG8X25.hex
5. Under BOOT IMAGE, enter 8X25_msimage.mbn
6. Press LOAD XML DEF > navigate to your extracted JB firmware > select rawprogram0 > press OPEN.
7. Press LOAD PATCH DEF > navigate to your extracted JB firmware > select patch0 > press OPEN
8. PRESS DOWNLOAD
9. An warning message may appear, TIME OUT WAITING etc etc or COOKIE NOT RECEIVED. If the error is TIME OUT WAITING, press OK and then press SWITCH DEVICE TO DLOAD. Check the flare, it will show RESET FOR ENTRY QPST.
10. Exit EMMC SOFTWARE DOWNLOAD. Proceed to flash Jelly Bean BP Firmware and then flash Jelly Bean img dump.
11. IF ERROR IS COOKIE NOT RECEIVED, sorry it is still bricked.
JUST HIT THANKS BUTTON IF YOU LIKE MY POST
The Following 3 Users Say Thank You to Bonaman For This Useful Post:
Old 07-15-2013, 18:39   #2 (permalink)
Member: 291418
cookie (if present) not received error
receiving cookie not received error. please help?
the log file is as follow:
2013/07/03 14:15:55.095 Restart timeout set to 10 seconds
2013/07/03 14:15:55.095 StartSB2Download
2013/07/03 14:15:55.095 Begin SB2.0 Software Download
2013/07/03 14:15:55.095 Skip Reset: 1
2013/07/03 14:15:55.095 Lock phone
2013/07/03 14:15:55.095 Examine phone mode
2013/07/03 14:15:55.111 Get partition file name
2013/07/03 14:15:55.111 User specified flash programmer:
2013/07/03 14:15:55.111 Flash Programmer file:
2013/07/03 14:15:55.126 Examine phone mode
2013/07/03 14:15:55.126 Mobile not in download mode!
2013/07/03 14:15:55.126 SynchronizeConnection starting...
2013/07/03 14:15:55.126 Sending Hello to flash programmer...
2013/07/03 14:15:55.126 Disabling automatic polling.
2013/07/03 14:15:55.189 Try Hello with polling disabled...
2013/07/03 14:15:55.189 SynchronizeConnection succeeded.
2013/07/03 14:15:55.189 Sending Hello Packet
2013/07/03 14:15:55.204 Version info = 5 2
2013/07/03 14:15:55.204 Block size = 400
2013/07/03 14:15:55.204 Flash base = 0
2013/07/03 14:15:55.204 Device Name=eMMC:
2013/07/03 14:15:55.204 Flash ID size= 4
2013/07/03 14:15:55.204 Sectors = 128
2013/07/03 14:15:55.204 Feature mask = 0x09
2013/07/03 14:15:55.204 Sending Close 0
2013/07/03 14:15:55.204 Log: Cannot close when not previously opened
2013/07/03 14:15:55.204 ARMPRG error: 15, text: Cannot close when not previously opened
2013/07/03 14:15:55.204 CloseDownloader error
2013/07/03 14:15:55.204 Sending Security Mode 1
2013/07/03 14:15:55.204 eMMC user image present - skipping partition table
2013/07/03 14:15:55.220 eMMC user image: C: \ flare repair files \ 8X25_msimage. mbn
2013/07/03 14:15:55.220 Opening eMMC USER file
2013/07/03 14:15:55.220 Opening eMMC USER mode
2013/07/03 14:15:55.220 Sending MI Open mode 33 size 0
2013/07/03 14:15:55.579 Log: Open multi failed, unknown error
2013/07/03 14:15:55.579 ARMPRG error: 7, text: Open multi failed, unknown error
2013/07/03 14:15:55.579 Download end, status 103, error 852
2013/07/03 14:15:55.579 Exit SB 2.0 download with status 0x00000000
The Following User Says Thank You to kornholic For This Useful Post:
Old 07-23-2013, 11:01   #3 (permalink)
Member: 1984504
Sonork: normadz
paps
bt wala ka mga link panu magawa? hmmp
The Following User Says Thank You to greenjamez For This Useful Post:
Old 08-13-2013, 00:20   #4 (permalink)
Member: 2000281
emmc software download wont open.. it says "failed to connect to qpst server" .. what should i do? please help
The Following User Says Thank You to vanillapanda For This Useful Post:
Old 08-14-2013, 03:46   #5 (permalink)
Member: 2001249
wala po ba link ng mga files jan?
The Following User Says Thank You to enchonggo For This Useful Post:
Old 09-10-2013, 22:38   #6 (permalink)
Member: 1633654
Sonork: p1ck
how to flash after (RESET FOR ENTRY QPST DOWNLOAD) show-up. and what tools to use flasing for JB?? Thanks and advance
The Following User Says Thank You to p1ck_kn0t For This Useful Post:
Old 09-14-2013, 07:25   #7 (permalink)
Member: 2025197
sinubukan ko po sya sir... ayaw magconnect ng emmc software downloader...
("failed to connect to qpst server")
Old 09-15-2013, 12:54   #8 (permalink)
fertxter's Avatar
Member: 1344255
Sonork: 1659066
Thanks Meter: 39
very good job bro keep it up .. =))
Pisot k rin :P
Old 09-18-2013, 03:29   #9 (permalink)
Member: 2027546
plz help where did you get this emmc software download?
Old 09-19-2013, 08:50   #10 (permalink)
Member: 2027546
same probs hir... . plz help us solve this problem........ i miss my flare phone
Old 09-23-2013, 16:00   #11 (permalink)
Member: 2031918
Cool qpst failed to connect
same problem here what should i do
Old 10-07-2013, 04:31   #12 (permalink)
phudzgsm2010's Avatar
Member: 1351276
Thanks Meter: 24
Hit properties then compatibality windows xp service pack 3 and you done
cookie error is the next problem
Old 10-07-2013, 05:08   #13 (permalink)
Member: 1846781
Sonork: 100.1597405
Thanks Meter: 7
here the link..
Tools
QPST-2.7.399
BP_JB_Firmware
JB_pcdrivers
EMMC_DownLoad_V1.2.4
Roadkil's Disk Image
The Following 3 Users Say Thank You to gsm khen For This Useful Post:
Old 11-18-2013, 23:37   #14 (permalink)
Member: 732120
Thanks Meter: 28
driver not installed on windows 7...plz help
Old 11-19-2013, 00:19   #15 (permalink)
Member: 2067820
Sonork: sansan02
Sir.. Mam pa link naman po ng File para magawa yan.. salamat
The Following User Says Thank You to sansan02 For This Useful Post:
Powered by Searchlight © 2014 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.58584 seconds with 7 queries
