Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
03-21-2010, 13:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: india
Member: 740513 Status: Offline Thanks Meter: 2,544 | Post: #1China Phone Format Method (MTK CPU) ....::::Format Method::::.... 1. Dead Phone 2. Restart Phone (with sim/without sim) 3. With Sim Phone Is Restart 4. Ringer Not Work 5. Mic Not Work 6. Bluetooth Not Work 7. Keypad Not Work 8. Phone Hang (Phone on but no incomeing/no outgoing/key not work) 9. Camera Hang 10. With MemoryCard Phone Not Power On 11. With Sim Card Phone Not Power On 12. Insert Sim 13. Emergency (network problem) 14. Call Hearing Spker not work. 15. Late Power On 16. Though u found any new solution by format add here, i found this. (All Are Tested By Me) this problem solv by format but its not true they allawes solved by format, so..... Before Format!!! Remember, befor format allawes readback ur phone current flash file, because sometimes after format previous on phone not power on, though not power on after format reflash ur phone with readback flash file (though ur CPU is MT6226BA, don't forgate Decypted ur readback flash file otherwise ur phone is dead still) Format Address: Recommanded Address for 16MB : 0x00E00000-0x00200000 (it work for me for allawes) 16M FLASH: first address(Hex) 0x00E50000;format(Hex) 0x001A0000 (not redy) 08M FLASH: first address(Hex) 0x00700000;length(Hex) 0x00100000. 04M FLASH: first address(Hex) 0x003F0000;length(Hex) 0x00010000. THE END |
The Following 4 Users Say Thank You to atulharnal For This Useful Post: |
04-01-2010, 20:15 | #2 (permalink) |
Crazy Poster Join Date: Aug 2008 Location: Lajas, PR Age: 58
Member: 846640 Status: Offline Thanks Meter: 10 | It means that if you had bricked your phone you can re-format it and the phone would be restore to it's factory state. But before re-formating you should do a back up of your firmware just in case you screwed up, that way you can flash the phone again. When using one of the flasher/reading software, you get an address, it looks like those address mentioned in the post were tested by him. |
05-27-2010, 12:56 | #5 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1149465 Status: Offline Sonork: [email protected] Thanks Meter: 1 | put the add pls............................................... ................... |
06-09-2010, 10:06 | #6 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1321089 Status: Offline Thanks Meter: 0 | Firstly, let’s have a look at the labels on the lower part of their LCD displays’ outer side. Both DV D-10 and DVH-595 come with 12.0 Megapixel, 20x super zoom, HDMI, and 3.0 inch LCD display. You could use the 5.0 Mega pixel CMOS lens to take photos as large as 12.0 megapixels with (interpolation). And the 20x super zoom means 5x optical zoom and 4x digital zoom, which enables you to take photos or videos from a much farther distance without effecting the image and video quality. HDMI output is a symbol of HD digital camcorders which indicates the transmission of high definition video clips. 3.0 inch LCD displays are both made of fashionable TFT material of 230,000 pixels, with which you can playback the photos and videos just after their being shot. As to the storage space, DV D-10 and DVH-595 also features same design. Built-in memory of the two digital camcorders is 100MB or so. And they could both be expanded through SD card up to 16GB, which could record high definition videos as long as several hours. ======================== orlando foreclosure homes tooth whitening |
how to Format the MTK phone without kill it with spiderMan | GalaxyMan | SpiderMan | 107 | 01-07-2011 01:50 |
Successfully formatting c1000 (spreadrum cpu) by mc- tool | laythjg09 | MC-Tool | 17 | 10-26-2008 17:20 |
Help infinity format method | nacino | Infinity-Box | 1 | 10-17-2008 19:50 |
11/04/08 : ET-BoX v1.61 Released - Added Bleu 551x & Improved Format for MTK | nonu_don | ET-BoX | 23 | 04-18-2008 10:04 |
All User China Phones Reapire Format Method | SHOEB AHMED | Chinese Cocktail | 13 | 12-28-2007 20:35 |
