Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 09-01-2009, 10:56   #1 (permalink)
gsmkiller173's Avatar
Member: 209582
Sonork: 100.1607015
Thanks Meter: 149
china keypad
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
(C) Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
(C) though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
(C) common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
orignal post from dhaka fourm
http://www.****************/chinese-m...html#post37480
The Following 7 Users Say Thank You to gsmkiller173 For This Useful Post:
Old 09-01-2009, 17:37   #2 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 5,014
this information world first published in this forum, here-
http://forum.gsmhosting.com/vbb/show...20&postcount=2
they copy it from here, and u copy it from there
The Following 2 Users Say Thank You to tkowsar For This Useful Post:
Old 09-02-2009, 09:38   #3 (permalink)
Member: 415645
Thanks Meter: 15
nice information gsmkiller
Old 07-14-2010, 12:36   #4 (permalink)
Member: 1092842
Thanks Meter: 12
china keypad solution
GSM NILBAGAN: china-6300-keypad-Solution.jpg
Old 07-14-2010, 12:36   #5 (permalink)
Member: 1092842
Thanks Meter: 12
show this links
Old 07-15-2010, 07:26   #6 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
Thanks Meter: 178
I have Alfatel H1 always repeat "0" character any solution??
Old 10-20-2010, 11:12   #7 (permalink)
sekar_k's Avatar
Member: 686254
Thanks Meter: 46
nice information gsmkiller thank you.....................................
Old 01-16-2013, 05:50   #8 (permalink)
Member: 1433538
Old 01-16-2013, 08:46   #9 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Reball cpu ic n replace problem will solved.....
Dont forget to say thanks to me if worked...
Hi-Tech Gallery
www.facebook.com/hitech.gallery
+91-9074669925
Old 01-16-2013, 08:48   #10 (permalink)
Member: 1834832
Thanks Meter: 1,450
heat cpu if not work reball n replace it if not sucess change cpu..
dont forget to say thanks to me...
+91-9074669925
6700c keypad problem luyanda Nokia Hardware & Hardware Repair 20 04-09-2014 10:16
china keypad problame rcpabari Chinese Models & Cloned Phones 5 11-08-2011 06:23
c66 china keypad not working can this is software shani72 Chinese Models & Cloned Phones 2 09-26-2009 11:03
M660 Suny ericsion china keypad ratan_deb Chinese Models & Cloned Phones 1 03-14-2009 06:35
china keypad not working gsm-world Chinese Models & Cloned Phones 12 11-17-2008 07:35
Page generated in 0.19880 seconds with 9 queries
