-   Chinese Models & Cloned Phones (http://forum.gsmhosting.com/vbb/f457/)
-   -   china mobile on emergency (http://forum.gsmhosting.com/vbb/f457/china-mobile-emergency-691828/)
zeeshan tayyab 03-02-2009 15:36
bro,some brand new china mobiles are on emergency mode and does not shows signals,any tested solution.
asif123456789 03-02-2009 15:47
chinge imei dear of this
shakeelzaffar 03-02-2009 15:56
Yes only change imei problem will solve tested many time.
gooshi_shah 03-02-2009 16:34
thanks brother
i do manual farmat now?
zeeshan tayyab 03-03-2009 08:42
not effective,still same
kamikhan 03-03-2009 09:16
i hv changed imei, unlock , formate but same problem
thomp4pal 03-03-2009 16:19
check and change PA., all will be okay.. i done many by change PA
aquilesvap 03-15-2009 03:42
Thanks, but how I can change PA?
thomp4pal 03-15-2009 11:34
1. Look for Exact PA IC from other brands of china phone
2. When u get same PA, Remove the one from the faulty phone with an SMD Rework station ( Note the Position and Notch of PA ic).
3.Now Remove PA ic from other board, be sure the ic is good... Resolder it On your own phone in the correct positioning.
4. Now test phone, if not work Rehot cpu...
B.R
thomp4pal
Mr. Right 03-15-2009 12:23
its hard ware problem not software or changing imei, just try to check its antena components
.::skybird::. 03-15-2009 13:02
Just Format your phone with any tool then write the eeprom and full flash.
.::skybird::.
asadnow2k 04-20-2010 15:43
i am unable to find few firmwares as they are realy new... :P
zeerik 09-23-2010 05:28
the best way .......search working phones of same models in local market and read flash then write the read flash in faulty mobile:)
skheman410 10-20-2010 10:48
hi guys in some new china handset shows emergency.
I format the phone & also checked IMEI no. ok
but still same.
is there any solution for it
plz HELP me
mane_15 10-21-2010 05:38
very hard solution dear,,,,,thnksssss
Page generated in 0.24807 seconds with 5 queries
