Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 02-09-2011, 09:24   #16 (permalink)
Member: 668970
Thanks Meter: 3
i think changing imei is not proper solution ,just reball the cpu your problem will be solved
i tried many chinese phone.
Old 07-12-2011, 06:59   #17 (permalink)
Member: 962648
Sonork: pavan
Thanks Meter: 9
i m change imei still same pro
Old 07-12-2011, 13:46   #18 (permalink)
Registered User
Member: 1394524
Sonork: pongshie
Thanks Meter: 10
any solution bro. i have same problem for emergency china phone i do same but still d same please help....
Old 10-10-2011, 08:11   #19 (permalink)
Member: 1588953
same problem imei is ok ................................................
Old 05-24-2012, 20:32   #20 (permalink)
Member: 647758
Thanks Meter: 6
dear member not imei problem for emergency its only network ic problem take care
The Following User Says Thank You to mallick_5x For This Useful Post:
Old 05-24-2012, 22:07   #21 (permalink)
Member: 535742
Arrow
what is parameter? when i use program most of time it says parameter is field .how can i solve it .help me pls
The Following User Says Thank You to GETAHUN For This Useful Post:
Old 09-29-2012, 00:43   #22 (permalink)
Registered User
Member: 1202860
if imei problem it shows INVALID SIM.
emergeny problem may be antenna components or pa problem
Old 09-29-2012, 10:45   #23 (permalink)
..:rubelstar:.*'s Avatar
Member: 1615212
Sonork: 100.1597410
Thanks Meter: 114
Hello Bro Post C.P.U Type...........
Old 10-01-2012, 03:44   #24 (permalink)
samo_d1's Avatar
Member: 1483881
Sonork: 100.1612698
Thanks Meter: 93
Some time imergency solved by rebuilding imei
and some time it is hardware problem
in that cases first check imei and then if phone is mtk based write good nv file
if not solved then check hardware by changing pa and reheating cpu
Old 10-05-2012, 06:17   #25 (permalink)
Member: 1138587
Thanks Meter: 4
I solve this problem many time 1st chek antina ways 2nd change pf problem is same change network crystal ic ur problem is 100% solve this trik i rpair 90% hendset in emergency mode
Old 10-23-2012, 13:18   #26 (permalink)
Member: 744022
Thanks Meter: 33
change p.a tested by me many times or flash ur mobile with working flash file
Old 09-12-2013, 13:38   #27 (permalink)
Member: 1793654
Sonork: Roshan 123
m-tech 18i 8mb flash file please send ppppppppppppppllllllll
Old 10-28-2014, 05:09   #28 (permalink)
Member: 2280961
Thanks Meter: 10
All China Mobile MT6250 & 6260 Cpu NO SERVICE. Only NO SERVICE not Emergency. Many handset tested by me.
All China Mobile MT6250 & 6260 Cpu NO SERVICE | Shamim
Emergency in china mobiles Tahir Riaz Chinese Models & Cloned Phones 26 04-08-2014 09:09
how do i activate internet on my china mobile kbsiti Chinese Models & Cloned Phones 3 05-25-2012 12:37
china mobile on calibration mode,please helpme!!!!!! faju Chinese Models & Cloned Phones 25 03-05-2011 06:58
about to install java on china mobile phone harry5641 Chinese Models & Cloned Phones 3 09-11-2010 02:58
need help on flashing china mobile phones tewariamit Multi-box LITE 4 06-04-2008 03:59
Page generated in 0.16445 seconds with 9 queries
