Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
11-16-2010, 13:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: ODISHA Age: 38
Member: 843479 Status: Offline Thanks Meter: 48 | Imei problem please help #98999 + 9 where is the problem how can i solve it |
The Following User Says Thank You to vikashmeher For This Useful Post: |
11-20-2010, 03:33 | #5 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608516 Status: Offline Sonork: 100.1607007 Thanks Meter: 123 | boss complete format ur phone with inifinity and write no with infinity on imei 1 and 2 in mode 3 in 2.19b version after that repair security area ur problem will 100% solve |
12-21-2010, 17:21 | #7 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1465492 Status: Offline Sonork: nilesh_punjabi@yahoo. Thanks Meter: 1 | COM9 [Serial2] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7403:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: DEWAV25_GEMINI_PCB01_GPRS_MT6225_S00.T68D_V41_L200 _ET.BIN project-id: T68D_V41_L200_ET, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range Finished, time used: 1 min 14 sec Remove/Install battery now ! |
12-22-2010, 13:32 | #8 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: Narayanganj
Member: 888599 Status: Offline Sonork: 100.1600952 Thanks Meter: 124 | Quote:
bro, listen your problem will be solved, don't worry . you are using infinity. so follow the following step.. 1. open Chinese miracle 2. go service option 3. input your phone backpart imei, in the imei box & if you have duel sim then input ime 1 & select the option ime1 for duel sim mono cpu at the below of ime text box(you should use second ime option after first one successfully written). 4. Finally press repair blocked. then input ime 2 & select the option ime2 for duel sim mono cpu & press repair blocked again When you successfully write your both 2 ime 's your phone will work fine. Thanks | |
