Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
03-09-2009, 11:26 | #33 (permalink) |
Junior Member Join Date: Mar 2009
Member: 990338 Status: Offline Thanks Meter: 0 | CHINA Mobile Phones Secret Codes Hey, friends None of these numbers work for me, I have a chinese M188 Mini Iphone, please help me!! I need the number of "engineering mode", my phone can't works in my country and I need select 1900Mhz band. Thanks |
03-17-2009, 20:38 | #36 (permalink) |
Junior Member Join Date: Feb 2009 Location: Philippines Age: 39
Member: 982551 Status: Offline Thanks Meter: 2 | hi to all...anyone knows what is the OS of china phone N95 QS610?.... and how to unlock its code without sim???? pls let me know....thanks in advance!... |
The Following User Says Thank You to bharacuda For This Useful Post: |
03-17-2009, 20:42 | #37 (permalink) | |
Member: 982551 Status: Offline Thanks Meter: 2 | Quote:
can u help me pls??....do u know what is the OS of N95 china fone and how to unlock its code without sim?.... and can i format N95 8GB china fone to symbian OS??.... thanks and mor POWER..^^ | |
03-24-2009, 14:33 | #38 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | All Usefull samsung Code's *2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed} *#2255# = Call List #*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code #*1200# = AFC DAC Val #*1300# = IMEI #*1400# = IMSI #*2562# = ??? White for 15 secs than restarts. #*2565# = Check Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts. #*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got Vibrator) #*7683# = Sleep variable ( #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF *2767*3855# = E2P Full Reset *2767*2878# = E2P Custom Reset *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode #7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings *335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGH***X/1.0] #*566335# = Wap Model ID [SEC-SGH***X/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model ID to standart E-900 And D-900 Codes *#9998*5282# Java Midlet Menu *#3243948# Digital Audio Interference Off *#32436837# Digital Audio Interference On *#1111# Software Version *#2222# Hardware Version *#1234# Firmware Version *#92782# WAP User Agent *#927827# WAP WAProfile *#0228#/*#9998*228# Battery profile * # 0842 # Vib test * # 0746 # SSMS MEMORY * # 0638 # SIM SIM network ID * # 0778 # SST Sim service Table * # 0289 # Buz test * # 0782 # RTC (RealTimeClock) (# = Refresh) * # 9998*228 # Battery Profile * # 9998*842 # Vib test * # 9998*746 # SSMS MEMORY * # 9998*638 # SIM SIM network ID * # 9998*778 # SST Sim service Table * # 9998*289 # Buz test * # 9998*782 # RTC (RealTimeClock) (# = Refresh) * # 9998*968 # YAMAHA OF OK ONE * # 9998*76 # Product NUMBER * # 9998*377 # error memory * # 9998*5646 # GPRS Logo ---------------------------------------------- Code, whose effect and/or function I exactly do not point * # 9324 # monitor? (with the red key velassen) * # 32436837 # DAI ON? * # 22766 # Automatically Recive call? * # 227633 # manual Recive call? ---------------------------------------------- !!! RESET code!!! !!! these codes use only if you know which it does!!! !!! Thus data in the Handy are deleted!!! * 2767*3855 # FULL RESET * 2767*2878 # CUST RESET * 2767*927 # WAP RESET * 2767*667 # MMS RESET * 2767*36245 # email RESET Try this to unlock lots of models also. *2767*2878# *7465625*638*00000000*00000000# #7465625*638*00000000# Samsung *2767*3855# - FULL E2P RESET *2767*2878# - CUSTOM E2P RESET #*7337# - UNLOCK *2767*688# - UNLOCK *#0523# - CONTRAST *#9998*523# - CONTRAST *#8999*8378# - Service Menu (X100) For zv10 unlocking *7465625*228# Tested ! secret codes 100% work -------------------------------------------------------------------------------- secret codes 100% work code works 1000%!!! -------------------------------------------------------------------------------- try 2 best.all of code are tested .enjoy urself. motorola w220 display problem *#**367628#+send key master reset *#**778337#+send key E2p reset O2x1 reset password *#9999# Hang talk and power button together [??]secret motorola mpx200 codes engineering menu, test mode, logs, etc. Enter in the top secret 'Engineering Mode' on your MPx200 entering: *#**364# on your keypad then press the Green Button other interesting codes are: * # * * 3 7 2 # FQC (test mode) * # * * 3 6 4 # Engineering menu * # * * 2 6 6 * 0 # Set as data COM port * # * * 2 6 6 * 1 # Set as log COM port * # * * 7 9 7 # Time to failure timer & Power down code * # * * 2 2 6 3 * 0 # Set to default Band * # * * 2 2 6 3 * 1 # Disable GSM Band * # * * 2 2 6 3 * 2 # Disable DCS Band * # * * 2 2 6 3 * 3 # Disable EGSM and DCS Band * # * * 2 2 6 3 * 4 # Disable PCS Band * # 9 9 9 # which displays the command log * # * * 8 3 7 # Version info (some roms doesnt have implemented) Remember guys play at your own risk L6 i-mode Codes -------------------------------------------------------------------------------- This Mitsibushi codes work with L6 i-mode hold * 65512890 for reset hold * 5806 sw version hold * 487989 NS lock menu hold * 482896 CP hold * 574243 NS hold * 967678 SP hold * 362628 IMSI hold * 787090 Lock net level hold * 787292 Lock net level TSM30 FULLRESET CODE ##*#9374 and press ok , b ::Service Codes:: ##**9987 Alcatel Master Codes - 25228352 - 25228353 - 83227423 (***/4,BH4,BF5,BG3,BF3/4..) ###337*07# - master reset (with SIM) ###847# - factory reset (with SIM) Alcatel 835 formating - **0102# Samsung *2767*3855# - FULL E2P RESET *2767*2878# - CUSTOM E2P RESET #*7337# - UNLOCK *2767*688# - UNLOCK *#0523# - CONTRAST *#9998*523# - CONTRAST *#8999*8378# - Service Menu (X100) For zv10 unlocking *7465625*228# Tested ! Philips #20021208# ok - 630 without SIM (erase flash) not sure *#7728*# - RSAV DONE (c630 reset code ) *#3849*# - ??? reboot *#3851*# - ??? reboot Philips 568 *01763*737381# - reset Pantech *01763*737381# - master reset (user data, user code) without SIM *01763*8371# - SW version *01763*6371# - UNLOCK *01763*3641# - Menu Panasonic reset(format) **7370# tryed and tested on my x700 *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55.. *369#(*) - MENU 7, 4, 6, menu, menu - lock menu *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..) **7370# **00012*00000000# **00032*00000000# LG 2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...) 2945#(*)- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu Security Removing Code For Lg 8110,8120. 47328545454# Or 277634#*# LG 2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...) 2945#(*)- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu Security Removing Code For Lg 8110,8120. 47328545454# Or 277634#*# U8180 old ...............49857465454# U8180 new .............492662464663# U8330 ...................637664#*# U8360 ...................*6*41*12## U8380 ...................525252#*# ALL LG 2G : 2945#*# 8110 & 8120 : 277634#*# U8130 & U8138 : 47328545454# 8180 old sw : 49857465454# 8180 new sw : 492662464663# 8330 : 637664#*# 8360 : *6*41*12## 8380 : 525252#*# LG 8550 885508428679#*# Phone Service Menu Code 8110 277634#*# 8120 277634#*# 8130 47328545454# 8138 47328545454# 8180 v10A 49857465454# 8180 v11A 492662464663# 8330 637664#*# 8360 *6*41*12## 8380 525252#*# 8550 885508428679#*# Phone Unlock Menu Code Older phones 2945#*88110# U880 was told that unlocking code for the phone is "0794070061" and method is to enter 142358#*# but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside). Plz help how to unlock it permanently After complete Flashing just Enter 142358#*# Sony-Ericsson > * < < * < * - Service menu < * * < - Lock menu VK Mobile *#79# - SW version *#85*364# (*) - hold menu 855855# without SIM (VG107) 85558555#(*)-hold 4268#(*)-hold (VG207) Voxtel 0124 - master code 0718#(*)- hold - menu (ST11, SC10, V100 without SIM) 4268#(*)- hold - show code (ST11, SC10 without SIM) *789(#)- hold - menu (V50, V300, RX100 without SIM) Motorola c350 english languge menu setting 1 1 5 2 6 (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on Nokia *#7370925538# (valet code reset) 6230 *#746025625# [*#sim0clock#] *#92702689# [*#war0anty#] Fly Bird S688 - #*301#02# send - with SIM menu: 7 - 10 - ok, #*8000#, #*3676# (reboot repair) V09, S1180 - *, 3 times down, 3 times up - service menu Enol *#987*00# - Service menu *#987*99# - Full reset *#900# - SW version Maxon *#9922# - menu, reset (without SIM) *#9900# - Software Version *#9901# - Software Version (PBatch) S60 Siries (SX1, 6600, N-Gage..) *#7780# - factory default *#7370# - full factory defaults (all user data reset) SX1 formating - * + # + power on 6600 formating - 3 + * + send + power on Sendo X1 formating - 5 + power on Mitsubishi *65512890 (*-hold) format FFS (Eclipse) * 3926 - (*-hold) test mode * 5806 - (*-hold) SW version *(hold) 787090 - trium 320 unlock menu Huawei (cdma) MASTER SECURITY CODE -309296 -3092 -9296 Pantech HX-550C (cdma) Full reset (phone code reset)- ##03*934#9367*192#397#7412569746 PWR, after reset - ##27732726 PWR and select "with uim" Samsung #7465625*638*12345678# ::Service Codes:: Alcatel Master Codes - 25228352 - 25228353 - 83227423 (***/4,BH4,BF5,BG3,BF3/4..) ###337*07# - master reset (with SIM) ###847# - factory reset (with SIM) Alcatel 835 formating - **0102# Samsung *2767*3855# - FULL E2P RESET *2767*2878# - CUSTOM E2P RESET #*7337# - UNLOCK *2767*688# - UNLOCK *#0523# - CONTRAST *#9998*523# - CONTRAST *#8999*8378# - Service Menu (X100) Philips #20021208# ok - 630 without SIM (erase flash) *#7728*# - RSAV DONE c630 reset *#3849*# - ??? reboot *#3851*# - ??? reboot Philips 568 *01763*737381# - reset Pantech *01763*737381# - master reset (user data, user code) without SIM *01763*8371# - SW version *01763*6371# - UNLOCK *01763*3641# - Menu Panasonic *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55.. *369#(*) - MENU 7, 4, 6, menu, menu - lock menu *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..) Sony-Ericsson > * < < * < * - Service menu < * * < - Lock menu j300 lcd reset ( -> *1*2*1* ) VK Mobile *#79# - SW version *#85*364# (*) - hold menu 855855# without SIM (VG107) 85558555#(*)-hold 4268#(*)-hold (VG207) VKMobile? Code 1: *#85*364# (hold * key in few second) --> Enter the hidden menu Code 2: 3807 # (hold * key in few second) --> Enter the test mode. Voxtel 0124 - master code 0718#(*)- hold - menu (ST11, SC10, V100 without SIM) 4268#(*)- hold - show code (ST11, SC10 without SIM) *789(#)- hold - menu (V50, V300, RX100 without SIM) Motorola (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on Nokia *#7370925538# (valet code reset) 6230 *#746025625# [*#sim0clock#] *#92702689# [*#war0anty#] 9210i formatting remove the battary Hold down Ctrl + Shift put in the battary keep waiting and holding the Ctrl + Shift when you see the nokia hands logo press ( F ) Fly Bird S688 - #*301#02# send - with SIM menu: 7 - 10 - ok, #*8000#, #*3676# (reboot repair) V09, S1180 - *, 3 times down, 3 times up - service menu Enol *#987*00# - Service menu *#987*99# - Full reset *#900# - SW version Maxon *#9922# - menu, reset (without SIM) *#9900# - Software Version *#9901# - Software Version (PBatch) S60 Siries (SX1, 6600, N-Gage..) *#7780# - factory default *#7370# - full factory defaults (all user data reset) SX1 formating - * + # + power on 6600 formating - 3 + * + send + power on Sendo X1 formating - 5 + power on Mitsubishi *65512890 (*-hold) format FFS (Eclipse) * 3926 - (*-hold) test mode * 5806 - (*-hold) SW version *(hold) 787090 - trium 320 unlock menu Huawei (cdma) MASTER SECURITY CODE -309296 -3092 -9296 Huawei ETS-668, 678, 688, etc Nam Programming: Debug Mode: ##44+Menu Debug Screen: ##33+Menu CDG2 Test enable: ##234+Menu CDG2 Test disable: ##432+Menu China Lang Select: ##123+Menu Blocking Debug Code: ###888+Menu Home System Only On: ##461+Menu Home System Only Off: ##460+Menu Pantech HX-550C (cdma) Full reset (phone code reset)- ##03*934#9367*192#397#7412569746 PWR, after reset - ##27732726 PWR and select "with uim" NEC Repair please wait on NEC N2xx *#3727372# IMEI *#06# Version * # 2820 # hardware reset *73738# (send?) Lock info * # 3210 # (send?) - SP lock * # 8140 # (send?) - Net lock SIM LOCK *#4960 # (send?) - info *4960*pass*pass#(send?) -lock #4960*pass#(send?) -unlock Lock Status * # 3210 # (send?) - SP lock * # 8140 # (send?) - Net lock *#CODE# CODES : 06 IMEI 7468658 SIM INFO 746255 SIM INFO 7464674 IMSI 2820 SW WERSION 79837 SW + DSP WERSION 49837 **************** 79786 Checksum 28453 Build Levev 737425 SERIAL NUMBER !!!! 73738 - 737247 Reapir History 7463424 SIMM Diagnostics 284538 Build Date 84769 Power ON 497837 Hysteresis 3643278746 Enhanced speed 3648658746 3 Volt Sim 347722 Clear Cause 627538 Market 7320 Network Lock 4960 USIM Card Lock 3210 SP Lock 8140 Coorporate Lock 5830 Unlocking Code !!! 6210 MSISDN - Current Phone Number TSM To check lock type in TSM3/4/5/5m? Turn ON the phone and type: *#9917# To enter Unlock Code in TSM100? Type: ****987 + Call To Enter Unlock Code in TSM100v/TSM30? Type: ##**9987 + Call SHARP sharp reset EEP 1, push at once key 0+3+right option key up+red key (white screen) 2, in sequence push key 0,1,2,3, right option key up,1 (service menu) 3, write 99 and push right option key up 4, write 01 and push right option key up (now start RESET EEPROM) Wait..... 5, push any key 6, push blue key menu (save) 7, power off //////////////////////////////////////////////////////////////////////////////////////// Sharp GX-10 unlock solution With Sim Card (of locked network) in phone: *01763*6371# and press M. In menu go to: SETTINGS->SELECT->SECURITY then in Security menu:MEP LOCKS->SELECT insert default security code 0000 In menu go to NETWORK and choose DEACTIVATE press SELECT and insert 812664697614 Press OK, phone anwser will be: DONE . phone unlocked Sarp Gx15/20/30 Tm100 Phone is on test mode you can see **** on phone display For finishing unlock folow the next steps : Press 1 on phone keypad Press 99 Press right top key Press 3 FOR UNLOCK or Press 1 FOR FACTORY DEFAULT Press roight top key Wait to see on display format ok Press right top key 3 times or more until phone is off MAXON for MAXON *#9917# #9917*network code# #9917*part IMSI# #9917*simlock SLPUK# #9917*IMSI# SG1000 Master Code Unlock 24681357 SG1000 Security Code Unlock *#*#1705#46 +ok (EEP reset) this code is for enter in serviçe menu *#*#1705# for innostream: *741*7373868# reset ok heck version *888*837# Engineering Mode *888*888# Master Reset *741*737381# *741*737381# *741*737382# THOMSON the code 49006045 AND TO ENTER CODE PUT 878 wit sim Sony Codes for the J-Series *#06# : Displays IMEI number *#00xx# : Changes language (xx is your country code) *#000# ... *#0000000# : Resets language to auto-selection *#7465625# = *#simlock# : Displays SIM lock status *#7353273# = *#release# : Display firmware version *#78737322867973738# = *#superfactoryreset# : Resets personal data (remove SIM card first) *#73287489263373738# = *#securitycodereset# : Resets security code to 0000 (remove SIM card first) *09*(PIN code)# : Turns PIN code on #09*(PIN code)# : Turns PIN code off Sagem If you search here in the forum sure you will find the answer , this forum is really a big library then next time i suggest ti you to use the usefull search button..... For example your IMEI is 35074635268234-2 take the four last digits without the 15th digit you have 8234 ----> 8+2+3+4 = 17 modulo 10 = 7 then x =7 if your firmware is DJ3,5C or DJ3,5D or DJ3,5E or DH3,5H then y=5 else if your firmware is DF4,5E or DF4,5F or DH4,6J or DJ4,6G or DG4,5H or DI4,6G then y=4 else if your firmware is JC3,6N or JC3,6O or JC3,6L then y=2 Now power on your phone without sim and put : *22663262??Y and Ok Salam For the last time on this forum... TEST MODE CAN'T BE ENTERED ON MYX3D, MYX5D, MIX5M, MYX6 SAGEM MODELS !!! SO STOP POSTING STUPID REQUESTS FOR TEST MODE CODE FOR THESE PHONES. STOP MYX6 UNLOCK CODE REQUESTS AS THERE IS NO CALC FOR IT YET AND PROVIDED FIELDS ARE UNUSEFULL. TEST MODE CAN BE ENTERED ON MW/MC9XX, MW/MY30XX, MYX3, MYX5: FOR MW/MC9XX: *0287257X WHERE X IT'S AN NUMBER BEETWEN 0 AND 9 FOR MW/MY30XX: WITH DX4,X FIRMWARE *2266326234Y WHERE Y=LAST FOUR IMEI DIGITS(WITHOUT CHECK DIGIT) ADDED MOD 10. MOD 10 MEANS THE REST BY DIVISION OF 10. WITH DX3,X FIRMWARE *2266326233Y WHERE Y=LAST FOUR IMEI DIGITS(WITHOUT CHECK DIGIT) ADDED MOD 10. MOD 10 MEANS THE REST BY DIVISION OF 10. FOR MYX3, MYX5: *22663262??Y WHERE Y=LAST FOUR IMEI DIGITS(WITHOUT CHECK DIGIT) ADDED MOD 10. MOD 10 MEANS THE REST BY DIVISION OF 10. X IT'S FIRMWARE DEPENDENT AND CAN BE A NUMBER BETWEEN 0 AND 9. U CAN ACCESS FIEL 94 ? THAT'S PERFECT ! WRITE TO FIELD 94 VALUE 0X01 AND U'LL PHONE (M51 AND ABOVE MODELS) WILL BE IN PERMANENT TEST MODE. Qantech sp unlocking *01763*737381# CDMA Secrets And GSM Secrets CDMA CODES <> Samsung sph-n240, n400, a460, a500, etc Nam Programming : Nam Set: ##Spc Test Mode: 47*869#1235 Debug Menu: ##33284,ok Service Menu: Menu+8+0 (#889) Reset (Life time, Clear Memory, etc): ##786,ok A-key: ##2539,ok Label Selection: ##3882,ok Label(Home, Work, etc) : **523,ok NGG Setting (Gateway, etc.): ##2769737,ok Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok Samsung sch-411, 611, n105, a100, a300, a2000, etc Nam Programming : Nam Set: 47*869#08#9 Nam Set: Menu+60 Test Mode: *759#813580 Test Mode: 5809540*45680 A-key: Menu+0, 25## External Audio: Menu+0, #### Debug Menu: Menu+8, 0415 or Spc Debug Menu: Menu+9, 0415 or Spc Brief NAM Programing: Menu+40,626 (not all version) LCD Contrast: Menu+45 (not all version) SIO Mode: Menu+49 SIO Mode: Menu+69 Samsung a300, a530, a610, a620, a660, a670, etc Nam Programming : Nam Set: Menu, 6, * Nam Set: ##3238, ok Nam Set: ##SPC (##000000), ok Service Menu: Menu, 9, * Test Mode: 47*68#13580 Test Mode: 47*869#1235 Samsung X, E, V, S-series (korean), e250, v420, s250, etc Nam Programming : Nam Set: 6548#0**4#6 Nam Set: 47*869#08#9 Nam Set: 74153697193 Test Mode: 5809540*45680 (88 - efs clear) Debug Menu: Menu(hold 2sec)+0, 6725 or 9720 or 1973 or 0415 Debug Menu: Menu+0(hold 2sec), 6725 or 9720 or 1973 or 0415 Samsung N356 (India version) Nam Programming : Test Mode: Menu, 5, down arrow, * Test Mode: **00## (in some flashes) Samsung i700, etc Nam Programming : Nam Set: Go to start and select "PHONE" from the drop down menu, dial #83587 Samsung i300, etc Nam Programming : 1. Tap on the Phone Icon with stylus 2. Press #907*9#0 ENTER LOCK should appear on screen 3. Enter OTKSL 4. SVC MENU will appear press 1 5. Enter 10 digit MIN and then press SAVE 6. Press SAVE again 7. Press 3 and then press SAVE 6 times 8. Enter the HOME SID and press SAVE once 9. Press END key twice <> Qualcomm qcp-800 Nam Pogramming : Nam Set: Menu+3+0+Spc Field Test: Menu+7+0+Fsc Kyocera 1135, 2255, 3035, 5135, 6035, Se47, etc Nam Programming : Nam Set: 111111+Jog Dial(Ok), Select "Programming"+Spc CAI Change: ##7738,ok Enable TTY: ##889,ok Life Timer, PRL, etc: ##786,ok A-key: ##2539,ok A-key: 2539,ok Tips: On some kyocera handsets the factory service module has not been disabled and the phone can be programmed without the spc by inputting. Nam Set: ##333333 menu (service) <> Sanyo 4900, 5150, 5300, 8100, etc Nam Programming : Nam Set: ##Spc+Ok+Key Down+Ok Advanced Setup: ##3282+Ok+Key Down+Ok+Msl A-key: ##2539+Ok+Key Down+Ok Version: ##**837+Ok+Key Down+Ok Debug Menu: ##FSC+Ok+Key Down+Ok Airtime menu: ##8463+Ok+Key Down+Ok Change CAI: ##7738+Ok+Key Down+Ok Vocoder: ##8626337+Ok+Key Down+Ok Reverse Logistic: ##786+Ok+Key Down+Ok Set IP Address: ##2769737+Ok+Key Down+Ok TTY On/Off: ##889+Ok+Key Down+Ok Ready Link: ##4636+Ok+Key Down+Ok Browser Init On/Off: ##4682+Ok+Key Down+Ok Picture Token: ##25327+Ok+Key Down+Ok Unknown Code: ##5282277+Ok+Key Down+Ok (SPC=000000, FSC=040793) Sanyo scp-A011, smp-A017, etc Nam Programming : Nam Set: F9(3 beep) + 0*72696#767 <> Nokia 3280, 3285, 3580, 3585, 5185, 6185, 8280, etc Nam Programming : Nam Set: *3001#12345# Software Version: *#837# Software Version: *#9999# Esn Number: *#92772689# Restart Phone: *#75681# Restart Phone: *#75682# Nokia 8887 Nam Programming : Nam Set: *3001#12345# Version: *#0000# Evrc: *#8378# Esn/Data/Timer: *#92772689# SID: *#743# Nokia 8587 Nam Programming : Nam Set: *#626#7764726# A-Key: #8159357022#4579# (26 digits) A-Key: #8159357022#4547# (20 digits) Version: *#0000# Version: *#837# Vocoder: *#3872# Change language: Menu 5, 3, 1 Change DM mode: *#7678# Debug Screen: *#8378# Debug: *#8380# Field Test Menu: *#83788# SPC Unlock, Factory Reset : Full Factory Reset: *#7370# Resets all settings including non-user changeable items (like SPC) NOKIA TEST MODE: 51xx, 61xx, 71xx, 3285, 6??x, etc : 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 0 0 and then choose OK. 3360, 6360 : 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 2 1 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 2 1 0 0 and then choose OK. <> Audiovox 4000, 9000, 9100, 9155, 9500, etc Nam Programming : (Power the phone on and wait until the little light on top goes out) Nam Set: 289+fcn+#+1 Service menu: fcn+00+fsc(000000) Test Mode: Hold (2,*,Rcl)+Power Test Mode Commands: 99 - download - flash phone 124 - inam data write 125 - version 126 - esn read 127 - sec_code 128 - lock_code 129 - is WFTV data write 137 - FSC code 138 - NPcode (nam program code) 139 - dscode 141 - restart 218 - Read_Addr 000 - is cdma mode 001 - is fm mode 002 - is pcs mode 008 - is reg read addr 020 - is lna_range Audiovox pcx-3500xl Nam Programming : Nam Set: ##2726+Send+1998+1+Spc+1 Audiovox cdm-100, 130, 135, 8300, 8500, 8600, etc Nam Programming : Nam Set: ##20022002+Pwr+1+Spc Audiovox 8610, 8910, etc Nam programming : Name Set: ##847446, end, 111111 Audiovox-107 Nam Programming : Nam Set: 45680*47*869#1 Audiovox CMP-3 Nam Programming : Nam Set: 45680*47*869#1 Dm Mode: Menu, 6, 6 Audiovox 9950 Nam Programming : Nam Set: ##3282 Audiovox Z800 (Audiovox 7900, Sharp) Nam Programming : Nam Set: m + # + envelope key + * + 1 Audiovox Thera (Toshiba 2032) Nam Programming : Thera Nam Programming User Manual - nam_thera.pdf AUDIOVOX TEST MODE : 9100, 9155: 1) Turn on the phone. As soon the phone comes on and the green light turns off press RIGHTARROW, 0, 0. The phone will ask for the "FSC Code", press 000000 then choose OK and press RIGHTARROW, RIGHTARROW. Your phone is now in test mode. 2) The signal strength is the number on the top right hand side of the screen. 3) To turn off test mode shut of the phone and then turn it back on. <> Motorola 7760, 7860, 2260, 8160, etc Nam Programming : Nam Set: Fcn,0000000000000, Rcl Nam Set: 7466 3 #, Fcn, Fcn Test Mode: Fcn, 00**83786633, Sto Motorola v60c, v120c etc Nam Programming : Nam Set: 74663#, Menu, Menu, Spc Nam Set: Menu, 073887, * (type quickly) Test Mode: Menu, 073887*, Spc Debug Mode: ##33284 Force the phone into DIGITAL ONLY mode: 1) ##33284 (Debug) 2) RIGHT Softkey (Next) Twice 3) Down arrow 10 times to "PrefMod" 4) RIGHT Softkey (Change) until you see "DigOnly" 5) LEFT softkey (Exit) 6) MENU then LEFT Softkey return to idle screen 7) ##33284 (The last 4 will not display if you have done it correctly) Motorola t182, c210, etc Nam Programming : Nam Set: ##1111 end Nam Set: ##298645665 end Short Nam: ##073887 sto Motorola v710, v730, v740, ms150, etc Nam Programming : Nam Set: 8378*# + press 3 times NATE (spc - 071082) Test Mode: Menu, 073887*, Spc Service Menu: #758353266#646# Motorola StarTac 2004 Nam Programming : Nam Set: 5759789*#, rec key (3)times (spc - 915037) Motorola ms200, ms230, etc Nam Programming : Nam Set: 5759789*# (spc - 915037) Motorola v6060 Nam Programming : Nam Set:147*369#456*0# Motorola Razr V3C Nam Programming: Nam Set: 74663 # clr clr Nam Set: #073887* , then SPC MOTOROLA TEST MODE : v60, c120, c331, etc: 1) Turn on the phone. Press MENU 0 7 3 8 8 7 * 2) The phone will require you to "Enter a Security Code", press 000000, OK 3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable" choose SELECT. Your phone is now in test mode. 4) Signal strength is the 3_rd number down on the left hand side of the screen. 5) To toggle between regular mode and test mode: Press MODE then quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU. 6) To turn off the test mode the phone must be in regular mode, then follow the above sequence and scroll down to where it says "DISABLE" instead of "ENABLE" and choose select. Motorola Bible - bible.txt <> lgc-300, etc Nam Programming : Nam Set: Menu, 9, Spc A-key: Press "Sto" 3sec, 2539** lgc-330w, etc Nam Programming : Nam Set: Menu, 4, 0, Spc A-key: 2539** lgc-510, v111, etc Nam Programming : Nam Set: Menu, 3, 0, Spc A-key: 2539** lgc-500, 800w, etc Nam Programming : Nam Set: Menu, 9 , 0, Spc Debug Mode: Menu, 7, 0, Fsc Debug Mode: Menu, 8, 0, Fsc A-key: 2539** Lg LX,VX-series, VX4400, VX6000, etc Nam Programming : Nam Set: ##Spc Nam Set: Menu, 0 Advanced Settings: ##2342 Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok A-key: ##2539,ok Reset (Life time, Clear Memory, etc): ##786,ok <> Sky All Models Nam Programming : Nam Set: #7583538324#626# Nam Set: *759#364*7388464# Min simple mode: #758353266#646# Irm simple mode #758353266#476# Voice memo: #8767#277# Test Mode: #7583538324#8378# A-key: #758353266#2539# Service Menu: Menu+4+0+Spc Service Menu: Menu+5+0+Spc <> Withus wce-100, 200, 300, etc Nam Programming : Nam Set: ##948487+Save Nam Set: ##948482+Save Nam Set: ##66835+Save SMS Settings: ##76766 NVM Rebuild: ##777464 <> Hyundai hwp-110 Nam Programming : Nam Set: #86904**89397# DM Mode: ##2740* (Open phone, inter code, close phone) Hyundai hgc-120, 130, 200 Nam Programming : Nam Set: #86904**89397# Hyundai hgc-310, 600, 610 Nam Programming : Nam Set: ##20022002+Pwr+1+Spc Code Field Test: ##20022002+Pwr+1+Master Code Hyundai Curitel h-100, 150, hx-510b, 520 Nam Programming : Nam Set: ##20022002+Pwr+1+Spc Code Field Test: ##20022002+Pwr+1+Master Code A-key: 2539** Debug Menu: ##27732726+Pwr Sar Test: ##27752345+Pwr Baud Rate: ##36**+Pwr DM Mode Enable: **1004+Pwr DS Mode Enable: **1005+Pwr Test Bell/Voice/Led/Dot: ##1122+Pwr RF Mode: ##2240+Pwr Ras Ram: ##2774+Pwr Cmux1: **0481+Pwr Cmux2: **0482+Pwr RX Mode Fax: **0492+Pwr RX Mode Data: **0491+Pwr RX Mode Reset: **0490+Pwr <> Huawei ETS-668, 678, 688, etc Nam Programming : Debug Mode: ##44+Menu Debug Screen: ##33+Menu CDG2 Test enable: ##234+Menu CDG2 Test disable: ##432+Menu China Lang Select: ##123+Menu Blocking Debug Code: ###888+Menu Home System Only On: ##461+Menu Home System Only Off: ##460+Menu <> Ericsson A1228c, T61, etc Nam Programming : Short NAM: 987+Menu Long NAM: 923885+Menu+Spc CDMA Mode: 904093+Menu ????og Mode: 904095+Menu QNC: 904097+Menu Debug Screen: 904090+Menu DM Mode: 904050+Menu Sony-Ericsson T608 Nam Programming : Nam Set: 923885, Joystick to the right, 111111 <> Epsilon vc-5x Nam Programming : Nam Set: **147258963## Programming1: **1232580## Programming2: **321456987## Version: **1470963## Debug: **000000## Menu_1: **078987## Menu_2: **1234756## A-key: 2539** Reset: **14789## <> VK-100C, 110C, 200C, etc Nam Programming : Nam Set: 153147539741593 Test Mode: 153147539123258 (88 - clear efs) < > Z510, Z710i(gcd-456) Nam Programming : Nam Set: Menu+0+Spc <> AMC450 Nam Programming : Nam Set: *74269#*748#96148063+SEL <> ZTE C150 Nam Programming: Nam Set: *983*3641# <> Gtran gcp-2000 Nam Programming : Nam Set: 01#737+Spc Debug Menu: 01#324+Spc Debug Mode: 01#727 Test Mode: 01#764+Spc System Test Mode: 01#768+Spc Gtran gcp-5000 Nam Programming : Debug Mode: 01#727+Spc Test Mode: 01#765 <> PANASONIC TEST MODE : Panasonic (Most): 1) Turn on the phone. Press #7764726# choose SEND 2) Scroll down to where it says "NAM 1" and choose OK. Scroll down to "Access To Level 4" choose YES. Scroll down to "Built-In-Monitor" and choose EDIT. 3) Press 1 and choose OK then choose BACK. The phone will say "Back To Level 1" choose YES. Now choose EXIT the phone will ask you "Exit And Save Change" choose YES. 4) Signal strength is the top right number on the screen. 5) To turn off the test mode follow the above sequence except press 0 instead of 1 at the "Built-In-Monitor" <> Synertek S200 Nam Programming : Nam Set: Menu+0+Spc Debug Mode: Test vibro/rx/tx: ##5555+Save Debug Screen: ##33+Save Debug Screen: ##523+Save RF Test: ####+Save Unknown code: ##325+Save <> Sony CM-M1300, 3300, Z200 Nam Programming : Nam Set: 111111+Ok(Jog Dial)+Select+Programming+Ok+Spc How to remove memory card Password Click Here GSM CODES LG To see version on LG 81X0 277634#*# To enter unlock code : 2945#*88110# IMEI (ALL): * # 06 # IMEI and SW (LG 510): * # 07 # software version (LG B1200 ): * 8375 # recount cheksum (LG B1200 ): * 6861 # factory test (B1200): #PWR 668 unknow (LG 500 ): 8060#* unknow(LG 200 ) *789# + send unknow (LG 500 ): 9270#* and 9278#* Simlock menu (LG B1200): 1945#*5101# Simlock menu (LG 510W, 5200): 2945#*5101# Simlock menu (LG 7020, 7010): 2945#*70001# Simlock menu (LG 500, 600 ): 2947#* lg 5300 :2945#*5301# how to read data calcfor LG510w: just read button not read cal. data adress: 0x1000004 size: 0x438 then read. MAXON *#9917# #9917*network code# #9917*part IMSI# #9917*simlock SLPUK# #9917*IMSI# SG1000 Master Code Unlock 24681357 SG1000 Security Code Unlock *#*#1705#46 +ok (EEP reset) this code is for enter in serviçe menu *#*#1705# Mitsibushi *#06# View IMEI *#0044# English *#0049# Deutsch hold * 4329 Net Monitor1 hold * 621342 Net Monitor2 hold * 5472 M4 Testmode hold * 5806 SW version hold * 5807 HW version hold * 936505 SW and HW version hold * 482896 CP Lock Menu hold * 574243 NS Lock Menu hold * 967678 SP Lock Menu hold * 362628 IMSI Lock Menu hold * 787090 Lock net.level hold * 787292 Lock net.level Firmware Press and hold C, enter 597, release C secret menu Press and hold C, enter 987, release C.Press OK debug mode Press and hold C, enter 397, release C phase-2 mode Press and hold C, enter 499, release C Turn off phone Press and hold C, enter 999, release C Motorola *#06# Imei Number. Motorola 8400 Secret Codes IMEI Nummer *#06# Telefonbuch“ aus dem Menü l?schen [],[],[],003,[],1,[] und “okay” Telefonbuch“ im Menü hinzufügen [],[],[],003,[],0,[] und „okay“ Monitormodus [],[],[],113,[],1,[] Monitormodus deaktivieren [],[],[],113,[],0,[] Ausgangszustand [],[],[],070,[],0,[] Motorola 8700 Secret Codes* IMEI Nummer *#06# Telefonbuch“ aus dem Menü l?schen [],[],[],003,[],1,[] und “okay” Telefonbuch“ im Menü hinzufügen [],[],[],003,[],0,[] und „okay“ Monitormodus [],[],[],113,[],1,[] Monitormodus deaktivieren [],[],[],113,[],0,[] Ausgangszustand [],[],[],070,[],0,[] Motorola T 2288 Secret Codes IMEI Nummer *#06# Motorola P 7389 Secret Codes IMEI Nummer *#06# Motorola L 7089 Secret Codes IMEI Nummer *#06# Motorola V 3688 Secret Codes IMEI Nummer *#06# Motorola V 3690 Secret Codes IMEI Nummer *#06# ** Das Zeichen [] erhalten Sie, indem Sie die *-Taste l?nger gedrückt halten //////////////////////////////////////////////////////////////////////////////////////////////////////// NEC IMEI *#06# Version * # 2820 # hardware reset *73738# (send?) Lock info * # 3210 # (send?) - SP lock * # 8140 # (send?) - Net lock SIM LOCK *#4960 # (send?) - info *4960*pass*pass#(send?) -lock #4960*pass#(send?) -unlock pass is 8 digits Lock Status * # 3210 # (send?) - SP lock * # 8140 # (send?) - Net lock code for repair n21 n22 n223 *#3727372# Nokia Nokia 1610 Secret Codes IMEI Nummer *#06# Software Version *#170602112302# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Nokia 2010 Secret Codes IMEI Nummer *#06# Software Version *#9999# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Nokia 2110 Secret Codes IMEI Nummer *#06# Software Version *#9999# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Nokia 2110e Secret Codes IMEI Nummer *#06# Software Version *#170602112302# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Firmware-Datum *#3283# bzw. *#DATE# Nokia 2110j Secret Codes IMEI Nummer *#06# Software Version *#682371158412125# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Firmware-Datum *#3283# bzw. *#DATE# Nokia 3110 Secret Codes IMEI Nummer *#06# Software Version *#0000# bzw. *#9999# bzw. *#3110# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Werkseinstellungen *#7780# Simlock info *#92702689# Nokia 3210 Secret Codes IMEI Nummer *#06# Software Version *#0000# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Nokia 5110 Secret Codes IMEI Nummer *#06# Software Version *#0000# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Provider lock status *#pw+1234567890+1 Network lock status #pw+1234567890+2 Provider lock status #pw+1234567890+3 SimCard lock status #pw+1234567890+4 Nokia 5120 Secret Codes IMEI Nummer *#06# Software Version *#0000# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Provider lock status *#pw+1234567890+1 Network lock status #pw+1234567890+2 Provider lock status #pw+1234567890+3 SimCard lock status #pw+1234567890+4 Nokia 5130 Secret Codes IMEI Nummer *#06# Software Version *#0000# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Provider lock status *#pw+1234567890+1 Network lock status #pw+1234567890+2 Provider lock status #pw+1234567890+3 SimCard lock status #pw+1234567890+4 Nokia 5190 Secret Codes IMEI Nummer *#06# Software Version *#0000# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Provider lock status *#pw+1234567890+1 Network lock status #pw+1234567890+2 Provider lock status #pw+1234567890+3 SimCard lock status #pw+1234567890+4 Nokia 6110 Secret Codes IMEI Nummer *#06# Software Version *#0000# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Nokia 6130 Secret Codes IMEI Nummer *#06# Software Version *#9999# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92772689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data 6. Seite insgesamte bisherige Telefonzeit (min) EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Nokia 6150 Secret Codes IMEI Nummer *#06# Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data EFR de/aktivieren *#3370# Half Rate de/aktivieren *#4720# Testmodus aktivieren *#746025625# Nokia 7110 Secret Codes IMEI Nummer *#06# Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data Nokia 8110 Secret Codes IMEI Nummer *#06# Software Version *#8110# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Servicemenü *#92702689# 1. Seite IMEI 2. Seite Herstellungsdatum 3. Seite Kaufdatum 4. Seite Letzte Reparatur/Upgrade 5. Seite Transfer User Data Testmodus aktivieren *#746025625# Nokia 8148 Secret Codes IMEI Nummer *#06# Tastensperre MENU + * Lautlos MENU + # Nokia 8810 Secret Codes IMEI Nummer *#06# Software Version *#0000# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Seriennummer *#92702689# 1. Screen Herstellungsdatum 2. Screen IMEI 3. Screen Kaufdatum 4. Screen Letzte Reparatur Nokia 9000 Secret Codes IMEI Nummer *#06# Software Version *#682371158412125# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Firmware-Datum *#9999# Nokia PT11 Secret Codes IMEI Nummer *#06# Software Version *#9999# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Nokia PT11NF Secret Codes IMEI Nummer *#06# Software Version *#170602112302# bzw. *#682371158412125# 1. Zeile Software Version 2. Zeile Datum der Software 3. Zeile Typ des Telefons Firmware-Datum *#3283# Panasonic GD55/G50/G51/G70/A100/A101/A102/X300: with or w/o SIM press *#369# and go to menu ?°SW Version?± - GD67/GD87/X60/X66/X100/X200/X400/X500: with SIM press *#9999# while phone searching for network - X200 : with SIM press #02# while phone searching for network - X6X : Power on the phone with valid sim card and tape this code : 52824** then tape 746, Menu, Menu then enter your code Philips PHILIPS DIGA *#06# IMEI *#3333*# Blocking list *#2558*# All time connected *#3377*# IMEI,FLAGS,SIM LOCK *#7489*# Security code ??? *#3353*# clear Blocking List PHILIPS FIZZ *#06# IMEI *#8377*# Software version *#1234*# Security code *#5644*# Service code PHILIPS SPARK *#06# IMEI *#2254*# Status register *#2255*# Some kind of monitor mode during dialing. *#2558*# Time connected to net. *#2562*# ??? number of reconnections *#2565*# Warm restart *#3333*# BLOCKINGLIST *#2377*# ???BERR Phone waits random time and reconnects to network. *#3377*# Information, SIM-lock *#7378*# SIM info *#7489*# SECURITY CODE *#7693*# Sleep mode *#7948*# Turn off phone *#8463*# Information on sleep mode PHILIPS GENIE *#06# IMEI *#2254*# STATUS REGISTER *#2255*# Some kind of monitor mode during dialing. *#2377*# ???BERR reconnect? *#2355*# Near Cell Mode. U can see parameters of three nearest cells *#2558*# Time connected *#2562*# number of reconnections *#2565*# Warm restart *#2772*# Base Station Paging Multiframe. *#2847*# HIDDEN MENU!: 5.5:Closed User Groups *#3333*# BLOCKING - list *#3353*# clears Blocking list *#3377*# SIM LCK *#4263*# Hs-OK:0 KO:0 , HNS-OK:0 KO:0 *#4377*# ??? battery charging ??? *#7378*# SIM phase *#7489*# Security code *#7693*# SLEEP-mode *#7948*# Turn off Samsung E710/715 *#32436837# DAI ON Digital Audio Interference On *#3243948# DAI OFF Digital Audio Interference Off *#9324# MONITOR *#0746# SSMS MEMORY:20 *#0842# vibra on *#0289# buzzer on *#4357# HELP (4357) This screen!!!!!!! *#7777# verze SW *#8888# verze HW *#9999# Revize HW *#0782# cas provozu, zapnit? a vypnit? - LIVE TIMER *#0523# 41 (80) menu: 12 *#0638# SIM: f23003 F230 030 *#0778# SST size: 10 *#9273696# Java D/L setting *#92782# Wap user agent *#9998*5646# change operator logo at startup *#9998*76# production number *#9998*968# view melody for alarm - YAMAHA OK *#0778# Sim Service table *#9998*523# or *#9998*0523# or *#0523# Display Contrast *#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos *#9998*5282# Java menu (GRPS/CSD settings for JAVA server) E700/S500 100%..... X100/X600???!!!??? #*566335# Wap model ID #*5663352# java model #*5663351# model #*53696# java download mode #*536963# serial enabl others disabled #*536962# HTTP enabl WAPSAR disabled #*536961# WAPSAR enabl HTTP dis *663867 MF file dumped *335 All MMS mes deled *2767*77667# Spain MMS settings *2767*78667# Portugal *2767*65667# Netherland *2767*29667# Czech *2767*28667# Austria *2767*48667# Italy *2767*37667# France *2767*85667# Uk *2767*33667# Germany *2767*73738927# MMS Reset???? *2767*77927# Spain WAP Setting are applied *2767*78927# Portugal *2767*29927# Czech *2767*65927# Netherlands *2767*28927# Austria *2767*37927# France *2767*48927# Italy *2767*85927# Uk *2767*33927# Germany #7263867# Ram Dump On #*3232# Current Mode - DCD mode #*3231# DCD en TRACE dis #*3230# TRACE en DCD dis #*7247# ?????? #*3683# ?????? #*3777# ?????? #*3779# ?????? #*8645# ?????? #*6428# MIC measuremnt CMD: Set, DSPMTCV11, MICHDW in cihard. opt #*6422# MIC dep RXdata CMD: Set, DSPMTCV11, MICHDW in cihard. opt #*6421# MIC on CMD: Set, DSPMTCV11, MICHDW in cihard. opt #*6420# MIC off CMD: Set, DSPMTCV11, MICHDW in cihard. opt *#7465625# Stav z?mku #7465625*28746# Aktivn? z?mek deaktivov?n *7465625*28746# Automatick? z?mek perzonalizov?n #7465625*2827# Z?mek Auto CP deaktivov?n *7465625*2827# Z?mek s?te se mus? aktivovat #7465625*2877# Z?mek Auto SP deaktivov?n *7465625*2877# Z?mek s?te se mus? aktivovat #7465625*28782# Automatick? z?mek podskupiny deaktivov?n *7465625*28782# Z?mek s?te se mus? aktivovat #7465625*28638# Automatick? z?mek s?te deaktivov?n *7465625*28638# Automatick? z?mek s?te perzonalizov?n #7465625*228# Aktivn? z?mek deaktivov?n *7465625*228# Aktivn? z?mek perzonalizov?n #7465625*746* ??????? *7465625*746* ??????? #7465625*27* ??????? *7465625*27* ??????? #7465625*77* ??????? *7465625*77* ??????? #7465625*782* ??????? *7465625*782* ??????? #7465625*638* ??????? *7465625*638* ??????? *#8377466# SW + HW info *#8888# HW info *#9999# SW info *#8999*8376263# komplet info *#8999*636# IPD info #*2677# ARM state: None #*0000# ?????? *#8999*324# Net monitor?? #*6200# #*6700# #*6900# #*7200# neplatn? ?roven pr?stupu #*6100# command #*6100# Executed *2767*3700# SGH-E700 BSI *2767*7100# SGH-S100 *2767*8200# SGH-V200 *2767*7300# SGH-S300 #0111*codigo# *2767*637# *2767*688# *2767*wap# *2767*media# *2767*mms# *2767*226372# Camera Reset *2767*688# MEP off *2767*927# WAP *2767*2878# E2P Custom reset *2767*3855# E2P Full reset *2767*2878# Sec reset #*7828# C??? Midi Ri51 #*5111# PI 0813 33 99 MSI 7 NA 0 18 P99 T00 CffHff #*2562# nejakej reset #*2565# no blocking General Defense #*3353# General defense Code Erased #*3837# reset ??????? #*3849# reset ??????? #*3851# reset ??????? #*3876# reset ??????? #*7337# reset ??????? #*5376# reset All SMS Deleted #*7222# Operation Typ: Class C GSM #*7224# Error!!!! #*7252# Operation Typ: Class B GSM #*7271# multi Slot Class 1 GPRS #*7274# multi Slot Class 4 GPRS #*2787# CRTP on - Batery options #*3737# L1 AFC DeltaF -36 NbAfcCorr 0 AdjustFoi 0 CumFoi 0 #*3825# Command #*3825# Executed #*5133# L1 HO Data Async HO 83 Sync HO 0 HO Fail 0 TCH 40 #*7288# GPRS Detached #*7287# GPRS Detached #*7666# SrCell data RAC 255 NMO 255 #*7693# Sleep Deact #*7284# Class B #*2256# Calibr - info #*2286# DATAbattery #*2527# GPRS switching set to class 4 #*2679# Copycat feat. Activated #*3940# External looptest 9600bps not avalible in SYSOL2! #*4263# handsfree mode Activated #*4700# Half rate deact #*7352# BVMC Reg vaule Set BMVC to 00H For Cmd set DEBUGBATTERY in cihard.opt #*8462# Sleeptime sinc SwitchOf #*2558# Time ON For Cmd set DEBUGBATTERY in cihard.opt #*3370# EFR Deact #*3941# External looptest 115200bps not avalible in SYSOL2! #*5176 L1 Sleep TOI N:5 TOI P:0 #*7462# SIM phase 3 #*7983# Voltage/Freg Deact #*7986# Voltage Activated #*8466# Old time #*2255# Call failed mode: Command not Implemented #*2285 nic #*46539 nic #*5143 nic #*7629 nic #*7646 nic #*7665 nic #*7633 nic #*7626 nic #*5174 nic #*5175 nic #*5177 nic #*5156 nic #*2282 nic #*5132 nic #*7276 nic #*2355 nic #*3333 nic #*3377 nic #*5187# L1C2G trace Activated #*6837# Official SW version: 120107A1 #*7524# KCGPRS: +data #*7562# LOCI GPRS: +data #*7638# RLC allwazs open ended TBF Actiated #*7632# Sleep mode Debug: +data #*7673# Sleep mode RESET #*2337# Permanent Registrtion Beep: NOT YET IMPLEMENTED #*2474# For Cmd set DEBUGBATTERY in cihard.opt #*2834# Audio Pth Mobile Normal #*3270# DCS support Deact #*3282# Data Deact #*3476# EGSM Deact #*3676# falh volume formated #*4674# IMSI: +data #*4760# GSM Activated #*4864 pro tento model nic #*5171 data #*5172 data #*5173 data #*7326# Accessorz: vibrator #*7676# Command #*7676# Executed #*7683# Sleep variable #*7762# SMS Bearer CS Activated #*7957# Command #*7957# Executed #*8465# Time in L1 +data #*9278# Command #*9278# Executed #*9795# WTLS key Reset #*2252# Current call: +data #*2836# AVDDSS Managment Deact. #*3877# Dump of SPY trace: +data #*7728# RSAV done sharp reset EEP 1, push at once key 0+3+right option key up+red key (white screen) 2, in sequence push key 0,1,2,3, right option key up,1 (service menu) 3, write 99 and push right option key up 4, write 01 and push right option key up (now start RESET EEPROM) Wait..... 5, push any key 6, push blue key menu (save) 7, power off Sharp GX-10 unlock solution With Sim Card (of locked network) in phone: *01763*6371# and press M. In menu go to: SETTINGS->SELECT->SECURITY then in Security menu:MEP LOCKS->SELECT insert default security code 0000 In menu go to NETWORK and choose DEACTIVATE press SELECT and insert 812664697614 Press OK, phone anwser will be: Sony-Ericssion *#06# Imei Number. >*<<*<* Software version. *#0000# Default English. |
The Following 6 Users Say Thank You to saeedullah_khan For This Useful Post: |
03-24-2009, 15:13 | #40 (permalink) |
Insane Poster Join Date: May 2008
Member: 768337 Status: Offline Sonork: [email protected] Thanks Meter: 8 | thanks for sharing.good work bro. |
03-25-2009, 23:35 | #43 (permalink) |
Junior Member Join Date: Jan 2009
Member: 951409 Status: Offline Sonork: buchi Thanks Meter: 1 | plz send me nokia hardwere repair dia CHINA Mobile Phones Secret Codes Default user code: 1122, 3344, 1234, 5678 Engineer mode: *#110*01# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Factory mode: *#987# LCD contrast: *#369# Restore factory settings: *#987*99# Software version: *#800# Software version: *#900# Set default language: *#0000# Send Set English language: *#0044# Send Set English language (new firmware): *#001# Send Service codes Fly: 2040(i) reset defaults: *#987*99# Send M100 software version: ####0000# MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send Set language to English: *#0044# Set language to Rgram v4.0by blackattack |
04-02-2009, 17:48 | #44 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1003125 Status: Offline Thanks Meter: 0 | chinese vertu Hi I have nokia vertu monza edition chinese *******, but my mic's volume is too low so Ineed engineering mode code to fix it PLESE HELP. CHIP : MT6227 I don't have the version of the firmwire. |
All china phones secret codes.................. | aleem26 | Infinity-Box | 5 | 08-03-2022 22:07 |
Samsung Mobile Sets Secret Codes | Nurettin Duman | Trident/AGERE Platform | 1 | 01-13-2014 19:01 |
Q2Q china mobile phone code | thomp4pal | Chinese Models & Cloned Phones | 1 | 01-14-2009 11:26 |
