-   Chinese Models & Cloned Phones (http://forum.gsmhosting.com/vbb/f457/)
-   -   ..::china n8 bad contact charger and battery not save problem::.. (http://forum.gsmhosting.com/vbb/f457/china-n8-bad-contact-charger-battery-not-save-problem-1344134/)
HUM 09-10-2011 00:23
this set already come from other repair shop
and its usb charging socket removed already and all prints on pcb are damaged
so i chk on nokia pin charger
so any solution mates?
B.thirumalaraju 09-10-2011 03:45
bro if you use nokia charger it out put is nearly 6volt and 600mamps to 750 mamps or high.where as china phone needs 5volt or 5.5volt
250mamps to 300mamps .so it say bad connect charger. use same charger or if there is n70 socket in phone then n70 pin solder to it's original carger your problem solved. post resualts
ryu84 11-21-2011 12:52
i had sucess to change 8legs ic bside usb connetor~now tat phone charging working fine~~tq
Page generated in 0.14479 seconds with 5 queries
