china phone show insert T flash My china phone show insert T flash after formating mmc using my P c any solution 4 this ? i am v8ing 4 u r re play |
format mmc by pc with "Fat" not Fat32" you found it in format box top 2nd option in "File System" |
Solution for MMC inserted Hi, It is hardware case. U have to just resolder mmc pins on board. 100% solution.If work then say thanks |
phone A and B , Card A & B ---- phone A cannot axcept card A but phone B axcept two cards 1) mmc card A inserted phone A showing phone insert T flash (cannot open multimedia) 2) mmc card B inserted phone A axcept mmc and oppening multimedia 3) then other card B inserted, phone A & B axcept mmc and oppening multimedia 4) card A not working phone A card A working wall phone B ,C , D ................................ |
bro. if u use formatting using data cable then u need to format ur set or reflash.try it. |
china phone show insert T flash Quote:
1-format phone with infinity 2-resold mmc socket 3-resold/change power ic 4-resold/change cpu your problem will be solved good luck |
