Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
07-01-2008, 07:32 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: PAKISTAN Age: 36
Member: 651927 Status: Offline Thanks Meter: 62 | china phone .sim cardregistration failed only with mobilink sim other sim working goo |
07-01-2008, 07:39 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | try to change IMEI .... china phone starts from 15****xx change it to 35*********x post result |
The Following User Says Thank You to eyestrain For This Useful Post: |
07-01-2008, 07:54 | #6 (permalink) |
Junior Member Join Date: Jun 2008 Location: Argentina Age: 49
Member: 802887 Status: Offline Thanks Meter: 6 | If you dont have box do this: You have to download chinese "imei changer"(search) conect the phone(on) to the usb, then load the soft, search for com port 30 o 31(this new com should appear after you connect the phone, if you want you can first load the soft(before conecting the phone), look at com ports, then exit) with the phone conected set the baudrate, write the imei that the phone has in the sticker below the battery and change the Imei... You should check the engineering mode(search for your code) of your phone and in Devices===>UART===>PS change to USB so you can use the USB to change IMEI. Now my problem: I have an IFOE P168+ (CECT P168+) with the MT6225 Chip, dual sim. I have flashing software, imei changer, MTK Format, and so on... Have the USB Standard Cable and one Serial made by me. The problem is that i made a mistake: I changed PS to USB (instead of UART) and entered a dangerous code: *#6810# that DISABLED THE ENGINEERING MENU and several other codes. The question is: HOW CAN I CHANGE THE PS TO UART without entering the engineering mode? Is there a way to do that? To change to UART or to revert this bad code so i can use the Engineering menu. I've reseted the phone, entered all the codes i have found but nothing happened, and searched the forum for two days. If you could help me i would be very glad, so i continue investigating ways to modify my phone. Thanks in advance. Regards, Robert. |
The Following User Says Thank You to robylp For This Useful Post: |
07-01-2008, 08:20 | #9 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | Quote:
PLEASE TELL ME HOW TO CLEAR MY PROBLEM B.R SHERRY MOBILES | |
07-01-2008, 08:49 | #11 (permalink) | |
Member: 802887 Status: Offline Thanks Meter: 6 | Quote:
If you dont have box do this: You have to download chinese "imei changer"(search) conect the phone(on) to the usb, then load the soft, search for com port 30 o 31(this new com should appear after you connect the phone, if you want you can first load the soft(before conecting the phone), look at com ports, then exit) with the phone conected set the baudrate, write the imei that the phone has in the sticker below the battery and change the Imei... You should check the engineering mode(search for your code) of your phone and in Devices===>UART===>PS change to USB so you can use the USB to change IMEI. | |
07-01-2008, 10:43 | #13 (permalink) |
No Life Poster Join Date: Jun 2006 Location: CANADA
Member: 292789 Status: Offline Thanks Meter: 636 | i have same problem in 20 sets CHAINA and TREND same IMEI it,s imei is 135790246811220 what i have to do i will cheng IMEI with INFINTy then its work ok and good but i am wored about all customers wath is wrong where comes problem....................???? its very big big problem how is possible all sets IMEI 135790246811220 same |
07-01-2008, 10:53 | #15 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | I am facing this issue since last 3 days and resolved the desired issue so many times. Quote:
1208 china phone code can i unlock with spiderman | ahmadge | SpiderMan | 2 | 10-12-2010 10:07 |
6120c working with 2 sim while other sim card registration failed | xim360 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-10-2010 06:12 |
6101 insert sim but only with my local sims... works with others | Burnt Cobba | Nokia Hardware & Hardware Repair | 12 | 12-04-2008 14:35 |
