chinese stuck on calibration hi! i got a chinese phone which is stuck on calibration! once u switch it on it ask u to touch the screen for calibration but whenever u touch it ask u to touch other place to complete calibration but the process never end! it always ask u to press somewhere else! is it a software problem or hardware? and how to solve it? |
It is very common problem with mtk proccessor, it is due to power ic change it 100% it will be ok |
first of all change the touch screen before change power ic |
First Test This Open The Phone Hold Phone In Hand Press Lcd ( Dont Too Hard ) And Run Calibration I Have Pased Calibratin In Many Phones By This Method May This Help You Also |
how do i reset phone that result into chinese words after formatting. it stayed in one place and refuse to calibrate.what do i doto solve this?any code to be press on it. |
FIRST CHANGE LANGUAGE TO ENGLISH *#0044# IF U CAN CHANGE LANGUAGE TO ENGLISH BY THIS CODE THEN U CAN UNDERSTAND WHAT IS THE REMAINING PROBLEM |
*#0044# for english n *#0000# for defualt language |
u change touch screen i think ur problem solved |
Infinity box can repair your touch screen calibration; actually what it does is bypasses the calibration mode |
yes infinity can solve your problum |
calibration error Quote:
-->properly calibrate the screen using your stylus if not possible use software to calibrate the screen....... |
