Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 10-01-2008, 15:50   #1 (permalink)
mve
Member: 874366
Ciphone 3g ( Insert Sim - Failed to register!)
Hello i just got my ciphone 3g, and inserted my sim card and it says insert sim, and when im trying to scan for a provider i get failed to register!.
The sim card is putted in correctly and ive tried different cards, i live in sweden and have tried with both 900/1800 and auto on scanning for bands.
Ill be looking around for a solotution and post it here if i found one out if none of you are kind and are fast to reply.
Signed,
-Marcus
Old 10-02-2008, 10:21   #2 (permalink)
Member: 792296
Thanks Meter: 39
Sorry I don't have a solution to your problem but could you tell me which languages your firmware supports???
Thanks
Old 10-03-2008, 04:33   #3 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
you can go to engeenering mode by *#3646633# look for Network Selection, Ban Sel. and change to 900/1800 or Auto Mode... press save and turn off your phone and then turn On...
** Do not try to change any other parameter ** if you change other parameter or option like fast Sim option , your phone can be dead!
The Following User Says Thank You to teknospc For This Useful Post:
Old 10-03-2008, 08:03   #4 (permalink)
mve
Member: 874366
Not to sound rude or anything but as i stated in my first post ive tried both 900/1800 and Auto mode.
Old 10-04-2008, 04:36   #5 (permalink)
Member: 876298
Hi! I am from Argentina. I have just received my ciphone 3g and I have the same problem! When I insert the SIM and after searching the network it says "No Service" (Registration Failed). I have also changed between 900/1800 and Automatic in Engineer Mode, but nothing hapened.
Any new idea?
Thanks!
Old 10-04-2008, 05:47   #6 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
OK i got some news about, try to change the scan method if you have the phone in Automatic Search, change to Manual Search and try , on screen appears all the Carriers on your Country ....
MVE: It's ok man, you not sound Rude , is just im read to fast your post... my fault brother
Old 10-04-2008, 15:20   #7 (permalink)
mve
Member: 874366
Hey, and how do i do that?
If i go into select network i get Fail to search network, and if i go in Selection mode it instantly says done and throw me back to the previous menu where i can chose, "new search" "select network" and "selection mode"
it sounds like it could be that becouse i got 5 bars in the top corner you know next to where it shows your provider and how good "connetion" u got to them. been in the forest and checked it and it drops down to 3-4 bars so i have connection with some provider atleast..
Old 10-05-2008, 06:52   #8 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
put a sim card, then go to network options , on network selection apperars automatic, press the left button to change Manual , then look for network now , they show you all your carriers .....
Old 10-06-2008, 14:56   #9 (permalink)
Member: 876298
Hi Itīs me again.
Is there any possibility that this phone is not quadband as manny people say, and it is just dualband? Perhaps that is why we are having this network connection failure, donīt you think? Itīs very strange, but I hope itīs not what Iīm thinking.
I will try what teknospc is recomending us and then I will let you know my results.
Thanks again!
Old 10-07-2008, 00:59   #10 (permalink)
Member: 876298
Thereīs no way to do what you are saying teknospc. As mve says, if i go into select network i get "Fail to search network", and if i go to "Selection Mode" it instantly says "done" and throw me back to the previous menu where i can chose, "new search" "select network" and "selection mode". There is no way to change from automatic to manual in "network Selection", at least I cannot do that.
Any new idea?
Old 10-20-2008, 21:51   #11 (permalink)
Member: 880936
Angry Failed to register--no service same here!
Hi!
After much assurance I got the ciphone 3g. And was told it wud work in Canada. However, after putting the sim--it picks NO SIGNALS, and says NO SERVICE!
Has anyone found a fix for this problem or have we been scammed?
Thank you
The Following User Says Thank You to usmle_9120 For This Useful Post:
Old 10-21-2008, 06:47   #12 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
Any new idea?
in that big letters put manual mode
Old 10-21-2008, 07:10   #13 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
Well Some supplier inform me about that phone, that Model of Iphone copy 3G have some problems with some carriers about sim lock and NO SERVICE errors, that's why the Chinese Manofacturer stop produce the sciphone 3G and build the Schiphone 3g+ now corrected, the problem is not by Software , is by hardware so if you have that phone, resend to your vendor and ask for 3G+, i get some sciphone 3G+ from my vendor on HK they arrive in 1 week, so i can test and post my experience here, i have 1 sciphone 3G " Not the plus version + ) and works very well here , we use 850/1900 Freq.
This info was get from a supplier, so i need to confirm in some areas 900/1800, but you can search the model 3G+ on web
Old 10-21-2008, 16:22   #14 (permalink)
Member: 876298
Hi!
Thanks you teknospc for your information!
What itīs very strange is that I live in Argentina and we use 850/1900 bands, but although you say i works fine in your area which uses the same bands, it doesnīt connect to the network here.
I have tried everything but changing to manual mode, as when I go to "Selection Mode" it does not allow me to change to manual.
Thanks!
Old 10-21-2008, 16:32   #15 (permalink)
Member: 880936
Requested update from my vendor...
Hi friends,
I fully agree with andresgd. You can't go to "Selection Mode" and change to manual b/c it does not allow the change- its shows DONE and kicks me back to the network option. Such an option doesn't exist!
Anyhow, I have contacted my vendor and they told me that they will contact the factory and give me an update. I will post it shortly.
Thank you.
KA09 failed to register dallasusa1 Chinese Models & Cloned Phones 18 06-18-2010 18:42
iphone 3g insert sim problm help bgreat iPhone 2 / iPhone 3G / iPhone 3GS 2 03-17-2010 04:45
Iphone 3G Insert sim 468492DF iPhone 2 / iPhone 3G / iPhone 3GS 2 11-12-2009 01:29
Chinese Ciphone 3g single sim tri-band lazarus9 Chinese Models & Cloned Phones 1 08-09-2009 05:55
xtelecom insert sim how to resolove???? adnanskyland SpiderMan 2 08-12-2008 04:40
Page generated in 0.43080 seconds with 8 queries
