Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 06-20-2008, 22:06   #1 (permalink)
Member: 420906
flashing anycall 5200+
i have found the tx and rx pins and some others.
is it possible to flash direct on the com port or do i need a box
there is a silver sticker behind the batery that says staright 5200+
Old 06-22-2008, 09:41   #2 (permalink)
.::skybird::.'s Avatar
Member: 594884
Thanks Meter: 1,553
Yes it can possible!!!
First of all Download MTK flash tool3.2 from Here
Use iterface infinity with it
run it then go in option
Select Baud rate = 115200
then select com port
Operation Method = NOR
Baseband chip option = Check baseband HW version
Then click format
select MTK all in one file if ask
select Manual Formate Fat + tick on Validation then click ok
the process will start for Formating.
best regards
Old 06-22-2008, 10:01   #3 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Then click format
best regards
anycall5200+ is not based on mt cpu.. it has sky cpu and it is double slider phone...and currently it is not possible to repair this phone
Old 06-06-2011, 05:54   #4 (permalink)
adytuuxx's Avatar
Member: 1223870
Sonork: ..............
Thanks Meter: 74
i have one piece stuck on calibrate touch after factory settings,haw can i solve this?
Old 06-07-2011, 09:53   #5 (permalink)
nae
Registered User
Member: 215866
Sonork: 100.1617874
Thanks Meter: 125
Old 06-07-2011, 14:23   #6 (permalink)
adytuuxx's Avatar
Member: 1223870
Thanks Meter: 74
ps:did you solved that?
PINOUT Anycall 5200 plz help navidno Infinity-Box 8 09-30-2008 20:48
Need Pinout Anycall 5200+ .:KHALIFA:. Infinity-Box 8 09-28-2008 12:21
Need Pinout Anycall 5200+ igi85 Infinity-Box 4 04-15-2008 18:01
Need Pinout Anycall 5200+ .:KHALIFA:. Various 3 02-14-2008 17:03
anycall 5200+ ketan.d.chauhan Infinity-Box 13 11-02-2007 22:16
Page generated in 0.23488 seconds with 10 queries
