Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 12-28-2008, 09:06   #1 (permalink)
Crazy Poster
Member: 747436
Sonork: 1580536
Thanks Meter: 7
Arrow E.T BOX for all China mobile
ET the BOX function introduces(30pcs cables)
it is formidable function support all chip serize scan automatically and may download the file for updating.
Supports MTK, ADI, SKY, TI, SPD , INF (Infineon), AGERE , OM , SI and so on may be automatic scan.even more convenice for API and BOOT etc chips automatic scan,it will sipport through update the masterl of the software to work for the chip serize development.
supports the double CPU self- definition the scanning.
The MTK series self- scans successfully demonstrates the CPU model directly, lets you distinguish main vice-CPU fast, facilitates processing.
Super powerful all -automatic function ,all intelligent operation.
1, Choose COM part automatically;
2, Discern the pinout automatically,without selected pinout model manually;
3, Discern the chip serize automatically; 4, The full-automatic USB and COM port defines the scanning;
5, Accelerate the scanning automatically;
6, Full-automatic scanning BOOT pinout of SPD chip,, no need to turn mobilephone on;
7, Full-automatic scanning SKY API, no need set up manually:
8, intelligently botton ,only press the botton to set the function instead of pull out the date wire and power clamp.
The independent development platform, the completely automatic transfer configuration files, the simplicity of operator, it is powerful.
1, simplicity of operator: Reads, flash,unlock, decipher, and format complete automatically completely, no need to fill in any address section, any fonts model,it is absolutely easy to be used,for solving all decipher defeat problem.
2, supports super high capacity fonts: large fonts such as kMFB512 NFB 1G the NFB2G , all 48 file would be read in directly the platform completes all transformations automatically.
3, super intelligence: Platform automatic diagnosis CPU, the fonts, the amount of memory, may solve the complete breakdown which cause by the all softwares.
4 support model :The double card mobilephone, the double calliper to treat the handset only, may be unlockthe unlocking, the decipher. Read-write complete procedure.
5 suport MTK series :read, flash,unlock format and decipher CPU such as 6205, 6217, 6218, 6219, 6223, 6225, 6226, 6227, 6228, 6229, 6230
6 support SPD serize: read,flash, format ,unlocking and decipher CPU such as 6600D, 6600E, 6600M, 6600I,6600R
software and hardware function of ET box not only can be downloaded and upgraded.
USB2. 0 high speed CPU and FPGA, the software and hardware can be downloaded and upgraded through the network to enlarge its function, the most importance that iit work in steady and high speed . it is limitless to upgrade forsupporting the newly chip, Just to download the file for software to upgrade itself .
24 route intelligence urges, self-defining arbitrarily.
24 route urges, all the flashing signals that can be defined, each pinout should be defined as signals such as RXD、RXD、RTS、CTS、DSR、DTR、USB D+、USB D-、VCC、GND
The comprehensive optimization of the power and electric circuit, the powerful short- circuit and the overflow protection, the power supply clamps and 24 rounte output sockets has many serizes of voltages to be possible to be selected, to meet the different need.
1, the power supply clamps with 24 rounte intelligence output socket is equipped with the overflow protection;
2,with the loudspeaker and the LED warning when it is in the short circuit or the overflow ;
advanced built-in USB HOST technology, USB defines and scans automatically accurately and fast.
Innovative use of industry adopt built-in FPGA IP CORE and USB HOST (USB host computer) technology for scanning . all scan finished automatically , accurately and fastly by the hardware built-in FPGA IP CORE and USB HOST , Verification of the FPGA strength of the leading technology hardware again.
expecially for SPD chip superiority:
Complete processing SPD serize chip of software problem! ( you just provide breakdown mobilephone to us)
Support CPU such as 6600D, E, M, I, R etc to read, to flash,to format unlock and the decipher.
Support the newestand the biggest fonts (KAG00K007A, 132MB).
Super powerful and standard function for deciphering!
Super function:
The software and hardware unifies perfectly, may online promote continually.
Advanced built-in USB the HOST technology, USB define the automatic scan precisely and fastly.
Support each big chip goup, including the newest SI chip.
Support the 22CPU scanning and demonstrates the CPU model directly.
powerful all- automatic function ,all intelligent operation.
The independent development platform, the completely automatic transfer configuration files, the simplicity of operator, its function is formidable.
The more it work ,the more it worth!
Automatic memory function.As to difficult to dismantle, damage and scan slowly of the chip can automatic memory define, the rate of scan mobilephone can be quicker when it be used to scan again!
Old 12-28-2008, 09:08   #2 (permalink)
Crazy Poster
Member: 747436
Sonork: 1580536
Thanks Meter: 7
MTK6223、MTK6226、MTK6228 Add new Decryte algorithms
Spreadtrum SC6600H (USB port) supported
Fix infineon 7870/7880 flash algo
http://www.gzhwdz.cn/etbox/MTK-6.0.rar
http://www.hengwei168.com/ProductsView.asp?id=1149
Airtel Live and Airtel MMS settings for ALL CHINA Mobiles atulharnal Chinese Models & Cloned Phones 2 04-01-2010 23:13
Get Mcnpro box for your China mobile ! Mcnbox Main Sales Section 0 04-22-2009 12:46
Universal Charger for All China Mobile Phone IPMART ipmart WebShop 0 02-27-2009 09:50
Page generated in 0.24832 seconds with 8 queries
