Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 09-29-2008, 09:18   #1 (permalink)
Member: 453862
Thanks Meter: 50
Emergency in china mobiles
Hi guys plz help me i have one chines 6300 and a n91i in emergeny
when i try to search network manually searches ok but not register
I changed imie in infinity box and after it sp unlocked but same problem
signals in emergency are full
pllz plz help
Old 09-29-2008, 09:46   #2 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,955
pllz plz help
some re-hot sim jacket pin and power ic, hope problem will solve.
The Following User Says Thank You to tkowsar For This Useful Post:
Old 01-04-2009, 04:08   #3 (permalink)
Member: 934438
tkowsar, what do you mean by re-hot sim jacket pin? can you break it down in laymans? i have a Chang Xing A868 which is a quad band phone. when i enter two sims that run on the 900 mhz freq, they both show up without incident. when i add a 850 mhz sim, i get the emergency showing up for the carrier name. how exactly can i fix this problem?
Old 01-04-2009, 04:15   #4 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 501
change IMEI 1st if nothing just write erom sir to work it back your phone
Old 01-04-2009, 04:18   #5 (permalink)
Member: 934438
how do i change the IMEI? what software do i use?
Old 01-04-2009, 04:26   #6 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
The Chang Xing A868 is not original Quad Band Phone, is Triband, the 850 Mhz do not work, i buy some of that phones and says quad band, for my luck we work on 850/1900 and that phone is 900/1800/1900 mhz!
Old 01-04-2009, 04:28   #7 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
also that phone have same problem on Honduras, Costa Rica and Panama
Old 01-04-2009, 04:32   #8 (permalink)
Member: 934438
so there is no way around it? what does changing the IMEI do?
Old 01-04-2009, 15:00   #9 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,955
use search button, various type cpu change imei already post many many time.
Old 01-04-2009, 15:04   #10 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,955
what type of tool u use for hoting br, i think you need to buy laser gun which is not destroyed your board plastic .
also re-hot/re-solder sim jacket pin where is pin connected to board.
Old 01-04-2009, 15:06   #11 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
same problem with my n99ii dual sim after formatting using infinity only emergency call change imei not work .. still the same problem
br
The Following User Says Thank You to raezak For This Useful Post:
Old 01-04-2009, 15:17   #12 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,955
br
try to write eeprom and full flash
Old 02-24-2009, 17:47   #13 (permalink)
Member: 770840
Thanks Meter: 6
c1000 charge chart plz
The Following User Says Thank You to albion13 For This Useful Post:
Old 02-25-2009, 05:15   #14 (permalink)
honey_bbc2001's Avatar
Member: 700711
Sonork: 111.333333
Thanks Meter: 155
friends cheng PA your problam solve
The Following User Says Thank You to honey_bbc2001 For This Useful Post:
Old 02-25-2009, 05:45   #15 (permalink)
Gsm Mardan's Avatar
Member: 897494
Sonork: 100.1581481
Thanks Meter: 1,102
yes try to eprom file all become ok
Network problems in China Mobiles.. sameer918 Chinese Models & Cloned Phones 11 10-30-2014 13:29
Plz Help Inset Sim in china mobile yrgant brain00000 Chinese Models & Cloned Phones 7 11-10-2010 16:36
Flash write error in china mobile umesh garg Infinity-Box 10 05-10-2010 17:27
how to check model in china mobile if not slip in back of battery mohd.asim Chinese Models & Cloned Phones 1 06-20-2009 13:13
can i add farsi in china mobile Mohsin-* Infinity-Box 4 06-07-2008 15:47
Page generated in 0.44803 seconds with 8 queries
