Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
12-21-2008, 12:56 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | 3D_SOUND_3sim 3Sim MT6226 CPU I have tried one that is available on support (UBT3A_2235_PCB01_GPRS_MT6226_S01.MS6EARZ2235716DA 1__K988_16m_En_Ru_Ar.B0M.bin) the fone powers on but with white screen.... The actual info taken before formatting was... COM3 [VCP0] selected module v2.71 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:E1C1:822E high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: UBT5_0239_PCB01_GPRS_MT6226_S01.MS7CEZZ0239616FC0. BIN ver. sw 2: MS7CEZZ0239616FC0, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00710000 Detected eeprom/ffs address is non-standard: 00710000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00710000 detecting eeprom/ffs size... eeprom/ffs size: 008F0000 ffs chip: 00 eeprom/ffs area: 00000000:00710000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done Finished, time used: 188 sec Remove/Install battery now ! Any one have this Firmware???Plz i need it urgently Br |
CSL Model Blueberry 3sim | nasagih | SpiderMan | 0 | 06-27-2009 09:30 |
i need flah file for n72,cpu mt6226 | hamidtamizkar | SpiderMan | 1 | 02-19-2009 08:41 |
N73 Need File Flash: Mt6226 Cpu Uid 464f71ae, S71pl127n | irada | SpiderMan | 1 | 07-08-2008 14:14 |
