G`FIVE charging problem Dear all G`FIVE F3 dose not show charging please is there any solution help me//////////////////thanks |
which model and with set some info need this |
br. which model reply here |
dear sir model is given G`FIVE F3 |
check carefully jeck of mobile |
g five f3 display showing charging but bettery not charging plz help |
be sure u are useing correct charger and second check charge legs voltage by useing multi-meter. B.R |
gfive u888 shows charging, but battery not charging. Voltage in battery pin is 0.97 to 1.01 volt |
the voltage in mobile battery pin is 2.68v, then it countdown to 0.56v then again it change to 2.68v and again countdown to 0.56v same happen |
what the solution of invalid charger of g five handsets |
use 3.7v jinner daiode between charging connector +ve and battary connector +ve |
gfive f3 not memory show plz anybody solution |
gfive L228 charge voltage over limit need solution |
