Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
09-17-2009, 11:50 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1120134 Status: Offline Thanks Meter: 0 | Help please I have purchased a clone iPhone and after many attempts at loading drivers and different software - the phone and PC don't communicate with each other. The drivers I installed are the MT6235 ones off this previous thread and the software is Iphone PCsuite V2.5.3.98 PCsuite shows phone - disconnected Please HELP!!! |
09-17-2009, 14:43 | #2 (permalink) |
Crazy Poster Join Date: Aug 2008 Location: Lajas, PR Age: 58
Member: 846640 Status: Offline Thanks Meter: 10 | Are the PC suite meant to be use with the regular usb cable? I'll have to try it to see if it works with the regular usb cable from the clone phone. I use Spiderman, which is way totally different program, this for flashing, and in order to use it, I need a flash cable, which is different from the regular usb cable. When you connect your usb cable from the phone to the computer with out the PC Suite, does it show a Mass Storage Device message? If it does, then the driver is working, please let me know the phone model that you are using. |
09-21-2009, 08:21 | #3 (permalink) |
Member: 1120134 Status: Offline Thanks Meter: 0 | Thanks for your reply! I am using the standard USB cable that came with the phone. When pluggin it in it shows the options: Mass storage Webcam COM port PictBridge Model on the back is: A1241FCC when plugging it in the PC sees it as MT6234. Thanks again for assisting me. |
09-21-2009, 21:14 | #5 (permalink) |
Junior Member Join Date: Feb 2007
Member: 451396 Status: Offline Thanks Meter: 0 | its not possible to do this through cable connection. You must use bluetooth to connect with your pc. Just make a bluetooth serial connection and see what com port does it use. Then go to pc suite and put the com port. You will see the connection icon in the tray. I' ve searched a lot for this solution and this is the only way you can connect your Phone to PC. |
09-23-2009, 09:39 | #6 (permalink) |
Member: 1120134 Status: Offline Thanks Meter: 0 | Thanks for your advice, I have tried via bluetooth - the PC sees the phone but the PC suite I have does not have an option for connection via bluetooth. It only has USB and WiFi options for connection of the phone. Maybe I have the wron version of PC Suite?? |
blackberry wap help please | philzfog16 | BlackBerry (RIM) | 3 | 05-01-2010 09:36 |
please help me...help help help please | maazi | Universalbox | 3 | 02-06-2009 06:58 |
please help please help | majidiomar2002 | CAR Electronics | 1 | 04-16-2008 10:19 |
