Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 11-08-2008, 11:28   #1 (permalink)
bgreat's Avatar
Member: 727235
Thanks Meter: 1,210
Arrow How to find rx and tx
FIND OUT RX & TX BY FOLLOWING METHODS FOR CHINA MOBILES
It is tasted and also you can test it.
1 step is, we need to find GND from phone.
2 step is, we should power on phone (operation with dead phone:
phone must be 100% dead by software)and take multimater put it to voltage.
3 multimeter (-) line put it GND and with (+) line check each connectors
, and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v
(it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v)
This way is too easy and you will save a more time.
For example!
You have got new brand China miracle phone with USB cable. It has got
12 pin. You must find (Infinity team give good Idea 1.2.3 punkts):
1) GND usually it has got 2 GND. (now we have got 10 pins)
2) We will uncheck USB + and USB- (VSS) just with checking by USB cable (now we have 8 pins)
3) By USB cable we also uncheck V bat+, ac adaptor + polarization (now we have 7 pins)
4) Now from this 7 pins you will find 1 or 3 not used pins (last operation we have 3 or 6 pins to find Rx Tx signals)
5) Now at last operation you should use good multimeter just to find Rx Tx with 1.7v-2.7v or 1.8v-2.8v
6) WHEN PHONE IS POWERD OFF TX AND GND WITH MULTIMETER MAKING BEEEEEP
(DIOD TEST OPERATION), WHEN PHONE POWERED ON IT WILL SHOW LIKE DIOD
RESISTANS 600-700 OHM BETWIN TX AND GND.
I think I have give for every body more informationís. Just try to
find. If you find 2-3 phone signals and you will be profi mobile Tx and
Rx signals finder.
Some times you will not find with this method some phones, but why we have forum?
This instruction will helpful for people who works in GSM repairing industry minimum 3-5 years.
How to find pinout for unknown model:
In most cases you need to know Gnd, Rx, Tx pins for flash/unlock
operations. What do do if you don't have cable or you have new phone
model:
1. find Gnd pin (it's required step, you can't continue until
you will know Gnd pin location)
2. find Charge pins (it's optional step, just to save your
time during future research)
3. find +Battery pins (it's optional step, just to save your time
4. connect cable Gnd to phone Gnd
5. try to connect cable Rx/Tx wires to all phone contacts one by
one (except Gnd, Charge, +Battery pins) and try to read flash from phone
6. if flash read procedure can start this means that pinout found Ok
and you can make other operations
Note about "Chinese models": a lot of different phones with the same
name exist on market (as well as many different name phones with the
same pinouts), so, if you see in our "cable selector" wrong pinout for
"Chinese models"it's good idea to find correct pinout acording to above
instruction and send found pinout information with full text from phone
back label to
The Following 22 Users Say Thank You to bgreat For This Useful Post:
Old 12-07-2008, 07:11   #2 (permalink)
Member: 669717
help cpf box I rx tx
Old 02-25-2010, 16:14   #3 (permalink)
Member: 1123097
Thanks Meter: 5
Please help!! I'm desperate!!
For example!
Rx signals finder.
model:
back label to
Hi!I bought a flash cable and now i want to make it so it connects with my phone (i bought a connector for my phone and a regular chinese flash cable). I'm having trouble connecting the wires as i don't know what pins they should be connected to. Please read below for the details and voltages.
Please help
I used a multimeter and read the voltages on my pins. I now have:
1- 0V
2- 2.63v (maybe tx/rx)
3- 2.69v (maybe tx/rx)
4- 2.78v (maybe tx/rx)
5-3.67v (battery pin)
6- 0v (it beeps when I check resistance, so this is GND)
7- 0v
8- 0v
9- 0.4v
10- 0.5v
Can you please help me decide how to connect my wires to these? I have red, black and green wires. I don't know which should attach to what pin. Is there a way to know wire should connect to which pin by checking the wires voltage???
When I checked the voltages on the wires, I got:
Black- 2.65v (maybe tx/rx)
Green- 0v (i think this is GND)
Red- 3.99v (maybe battery voltage)
Should I put the RED wire to pin 5 and try to read??
The Following 2 Users Say Thank You to Casanova2k8 For This Useful Post:
Old 10-17-2015, 05:59   #4 (permalink)
Member: 1550104
try this h
Old 10-17-2015, 07:58   #5 (permalink)
Member: 1550104
for tx rx china nokia 105 scarch 4sheared or contac me 09732007401
Old 01-02-2016, 15:50   #6 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 920
plz find this problem my g,five president g6 usb pinout damage how to find rx tx this model plz send this solution thnx advance,,,,,
Old 03-14-2017, 14:48   #7 (permalink)
Member: 2454652
Sonork: ejizeea
Nokia pinout
Pls I have Nokia 101 and 105 ,,,,,,pls help me with the pinout solution with normal usb cable that have GND,RED,GREEN,WIHTE .....GND=BLACK, GREEN=?, RED=?, WIHTE=?....... looking forward for your help.
Old 03-15-2017, 07:10   #8 (permalink)
Member: 2672786
Sir g my qmobile x11 usb pin damage and my mobile is dead reason sofware corrupt how to flash qmobile x11 and plz give me usb pinout ways plz
Old 11-19-2017, 10:11   #9 (permalink)
Member: 2676600
Red postive white d- and green dpostive
Sent from my Redmi 4 using Tapatalk
How To Find Rx .tx Signles . gopalhot Chinese Models & Cloned Phones 6 03-10-2011 09:35
@@..how we can find RX and TX by [email protected]@ mobi_soft Chinese Models & Cloned Phones 2 12-08-2009 09:13
HOW TO FIND [RX and TX] _ So Easy_in Your Phone New ! The_Dj Infinity-Box 5 11-28-2008 16:42
unable to find rx and tx ameho0102 MC-Tool 0 07-23-2008 13:00
HOW TO FIND RX/TX WITH ipHONE ON PAD?? frooze_angel PadFinder box 11 07-21-2008 12:46
Page generated in 0.38708 seconds with 8 queries
