-   Chinese Models & Cloned Phones (http://forum.gsmhosting.com/vbb/f457/)
-   -   How To Find Rx .tx Signles . (http://forum.gsmhosting.com/vbb/f457/how-find-rx-tx-signles-553576/)
gopalhot 06-19-2008 18:07
1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location)
2. find Charge pins (it's optional step, just to save your time during future research)
3. find +Battery pins (it's optional step, just to save your time during future research)
4. connect cable Gnd to phone Gnd
5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone
6. if flash read procedure can start this means that pinout found Ok and you can make other operations
HOW TO FIND RX .TX SIGNLES .
It is tasted and also you can test it.
1 step is, we need to find GND from phone.
2 step is, we should power on phone (operation with dead phone:
phone must be 100% dead by software)and take multimater put it to voltage.
3 multimeter (-) line put it GND and with (+) line check each connectors
, and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v
(it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v)
This way is too easy and you will save a more time.
For example!
You have got new brand China miracle phone with USB cable. It has got
12 pin. You must find (Infinity team give good Idea 1.2.3 punkts):
1) GND usually it has got 2 GND. (now we have got 10 pins)
2) We will uncheck USB + and USB- (VSS) just with checking by USB cable (now we have 8 pins)
3) By USB cable we also uncheck V bat+, ac adaptor + polarization (now we have 7 pins)
4) Now from this 7 pins you will find 1 or 3 not used pins (last operation we have 3 or 6 pins to find Rx Tx signals)
5) Now at last operation you should use good multimeter just to find Rx Tx with 1.7v-2.7v or 1.8v-2.8v
6) WHEN PHONE IS POWERD OFF TX AND GND WITH MULTIMETER MAKING BEEEEEP
(DIOD TEST OPERATION), WHEN PHONE POWERED ON IT WILL SHOW LIKE DIOD
RESISTANS 600-700 OHM BETWIN TX AND GND.
I think I have give for every body more information’s. Just try to
find. If you find 2-3 phone signals and you will be profi mobile Tx and
Rx signals finder.
Some times you will not find with this method some phones, but why we have forum?
I'm not saying it is 100% solution but I'm saying it is TESTED solution.
I'll make some guide or FAQ by pic. if I have a free time!
This instruction will helpful for people who working in GSM repairing industry minimum 3-5 years.
*** OFFTOP. I have some friends who don't know what is it Tx and Rx
signals, and why we using device. For siemens A35,C55 and C62 they
using 3 kind of cable (because they thinking that for each brand we
must use by one by cable).
rk19801 06-24-2008 12:04
thanks mate for youer help................
goherabbas 06-24-2008 12:19
thankss but the best way to find pinouts yuo parchase infinity box pin finder adapter its best
..::Rana Bilal::.. 01-12-2011 19:07
spider man is also great pinfinder box
starmobi 03-09-2011 06:05
For example!
Rx signals finder.
friend how to find 2pin rx tx
[email protected]
MTK-BOX 03-10-2011 07:28
Super Doctor 1.510 Tool,read the mobile port voltage,we can easy find the RX and TX,like MTK 6253 RX=2.8V,and TX=1.4V,and MTK other CPU RX=2.8,and TX=0.4 or 0.8
http://www.gsmthai-forum.com/gsm/ind...ach=4998;image
...:::::NP™:::::... 03-10-2011 08:35
Hello Mate Do You Write in English Language I Think More People Don't Understood Hindi Language.
Page generated in 0.16531 seconds with 5 queries
