01-30-2015, 10:02 | #2 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Bangladesh
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | bro Try This Easy Steps 1. Enter this code in your android dialler - * # * # 3646633 # * # * 2. Now you have to tap on callpad or connectivity or slide the screen. 3. Now find CDS information option. CDS stands for Common data service. 4. Once you found it, you’ll see Radio Information option there, just tap on it. 5. If your phone is single sim, then you’ll see one option there, and dual sim users will see 2 options there like Phone 1, Phone 2. 6. Write your IMEI code there like in this format : “AT +EGMR=1,7,”your imei code here” and “AT +EGMR=1,10,”your imei code here” . Example: “AT =EGMR=1,7”9000XXXXXXXXXXXX” After that tap on send command button. That’s it. |
04-26-2015, 09:43 | #3 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1482261 Status: Offline Thanks Meter: 0 | no problem just 2min Waiting for USB Port... Set PreLoader USB VCOM Port (COM51) Please Hold "ON" to connect with the phone...USB Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: NAND_NEW_006E Nand Flash Code: 002C00BC(00900066) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Waiting for USB Port... Set DA USB VCOM Port (COM55) Waiting for USB Port... Set PreLoader USB VCOM Port (COM51) Please Hold "ON" to connect with the phone... For 65xx Waiting for USB Port... Set COM134 Connecting AT Mode Read Information From the Phone... W IMEI1 OK: 35186106616790-9 W IMEI2 OK: 35186106616791-7 W IMEI3 OK: 35186106616790-9 W IMEI4 OK: 35186106616791-7 |
