Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 08-31-2008, 10:36   #1 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
Unhappy how to use pin finder check it
hello all its very easy to find rx tx with infinity pinfinder adapter
first install the pinfinder setup then insert infinity box then download new dongelmnager and open it click register dongel.......
then click next insert pinfinder to infinity choose hardware pinfinder then click upgrade after ok open padfinder setup exampel of trend t100 first insert l12b cabel on it insert it with infinity pinfinder insert power pin phone to rj45 pinfinder then click l12b on setup click power botton then phone power on note any phone not power on so you must make this jamper on show on pic the pic link is hare http://rapidshare.com/files/13703802...r_pic.rar.html
note insert jump only this wire show one picture not use slim jamper wire
remove capester then put jumper first pic is for infinity slim seconde is infinity+ therd is infinity+ yuo have infinity + so put jamper on box see second or therd pic then power on the phone phone will be on then click find botton holde prase the power botton of set and removed after opration complet then open the soft chines marcal set setting with infinity com change speed then click formate ffs all be done yous another opration see my post http://forum.gsmhosting.com/vbb/showthread.php?t=570033
dont forget to click thankss botton
your bro goher abbas
The Following 2 Users Say Thank You to goherabbas For This Useful Post:
Old 08-31-2008, 16:58   #2 (permalink)
zeeshan tayyab's Avatar
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
hi bro,
i m using infinity box and its original pinfinder for china fone flashing,sometimes i faced the problem with tx rx gnd points because some times its not properly work,when pinfinder finds the rx tx then infinity works but when pinfinder does not find rx tx then i feel myself in space because when i open the mobile and put the joints rx tx and try to format with infinity the box does not work to format or flash even i tried the charging jack points but problem the same,plz tell me how to solve this, because i 100% sure that there is mistake in my way so kindly help me if u understand my problem,thanx alot if u responce.
The Following User Says Thank You to zeeshan tayyab For This Useful Post:
Old 09-22-2008, 07:40   #3 (permalink)
Member: 788578
Sonork: adnan7040
Thanks Meter: 10
giv me pin finder adapter new.setup....plz,,,,,,
Old 09-30-2008, 10:39   #4 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
check our support site
Old 11-17-2009, 09:01   #5 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
infinity team is best and any new solution to flash or unlock phones with infinity contect with me it my msn id.
your bro
gohar abbas
how to use infinity pin finder........ unlock & flash Infinity-Box 11 02-03-2011 20:27
HOW TO USING ITUNES TO UPGRADING SONGS FOR v3I ,E98.... huong2 Motorola P2k 0 03-29-2010 20:41
How to Use Pin Out With CPF crazy_kamal CPF-BOX Ⅱ 0 07-16-2009 08:06
How to use Pinout finder for dual CPU phone muksforu Infinity-Box 4 01-26-2009 08:37
how to use pin finder as cable adapter? vazgsm Infinity-Box 4 10-26-2008 14:57
Page generated in 0.24990 seconds with 8 queries
