How to write imei pls help COM74 [VCP1] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 353548009409468 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:AA41:31C8 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 error: no any expected answer : wrong answer after chip cfi request flash: 01227E22212200:29EA0000000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 01227E22212200:04241200000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22212200:04241200000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22212200:04241200000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 01227E22212200:04241200000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 05/01 total flash region size: 04800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong data size at 0x0000C438, retry... warning: wrong data size at 0x0000C438, retry... read error recovered warning: wrong data size at 0x0001B038, retry... read error recovered warning: wrong data size at 0x00022838, retry... read error recovered warning: wrong data size at 0x0002A038, retry... read error recovered search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent warning: wrong data size at 0x004480E8, retry... warning: wrong data size at 0x004480E8, retry... read error recovered startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.75F77BC1.[U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04.BIN_7EECECA7].rpl ==================== New firmware found (v.3.24, database date: 01.10.2010): U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 75F77BC1 rom info ver: 04 sw version: U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04.BIN project-id: MAUI.07B.W08.16.M9D04, A7ECEC7E code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 5 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 03A00000 ffs/eeprom chip: 01 ffs/eeprom area: 00800000:00600000-03FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22212200:29EA0000000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ....................... ffs/eeprom: detect std location pass #1... .................................................. ...... ffs/eeprom: detect ext location pass #1... .................................................. .... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 13579024681122 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22212200:29EA0000000000 warning: wrong data size at 0x005EF400, retry... read error recovered flash: 01227E22212200:29EA0000000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 01227E22212200:04241200000000 error: wrong erase last sector 0x03FFFFFF error: format ffs failed Finalization Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U 26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_1 6_M9D04__system_log_75F77BC1_7EECECA7_20101023-112048.B0X.bin Finished, time used: 2 min 33 sec Remove/Install battery now ! HOW TO WRITE IMEI PLS HELP |
