I Core IC-V2000 2,5,7,8 keypad auto works need help I Core IC-V2000 2,5,7,8 keypad auto works need help Changed V3 10pin Charging pin Same problem |
if keyboard direct on pcb not connected by flex then u should 1st chk if any varistors using for filter keypad then remove them. if there no varistors or not a flex system keyboard then that problem cause cpu. you need to re-ball/change cpu. |
keyboard direct on pcb not connected by flex |
make backup flash then cheng cpu (i think its spd ) & flash ageine |
