Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
04-18-2008, 10:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 746552 Status: Offline Sonork: 100.1594844 Thanks Meter: 110 | sprint 7700 flash problem but this message are show: COM10 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC22E000000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: EC22E000000000:01AE0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb detecting chip #02 in region #00... flash: EC22E000000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb detecting chip #03 in region #00... flash: EC22E000000000:01AE0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC22E000000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: EC22E000000000:01AE0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb detecting chip #02 in region #00... flash: EC22E000000000:29EA0000000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 2 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC22E000000000:29EA0000000000 checking area[00000000]: 00000000-007FFFFF... flash: EC22E000000000:01AE0000000000 checking area[00800000]: 00000000-007FFFFF... eeprom/ffs found near: 00800000 Detected eeprom/ffs address is non-standard: 00800000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00800000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00800000 ffs chip: 01 eeprom/ffs area: 00800000:00000000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Fail Finished, time used: 47 sec Remove/Install battery now ! I will very glad infinity if you upload solution of this problem. because it's very very necessary for many man as like me. thank's |
The Following User Says Thank You to vertex777 For This Useful Post: |
04-18-2008, 10:52 | #2 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | sprint 7700 u full flash mtk3.20 cracked.flash file have this forum .bin file find u.1st full flash and format.and power on key hold 4 menit see your phone is ok |
The Following User Says Thank You to gopalhot For This Useful Post: |
04-22-2008, 14:30 | #3 (permalink) |
Member: 746552 Status: Offline Sonork: 100.1594844 Thanks Meter: 110 | plz gopalhot upload mtk3.20 cracked file and flash file or details address. many many thank's for you. |
Sprint 7700 flash file | unlockcare.us | Various | 36 | 01-04-2012 12:07 |
sprint 7700 charging problem | shaheb_anl | Chinese Models & Cloned Phones | 2 | 12-17-2008 14:14 |
sprint 7700 flash file need | shaheb_anl | Chinese Models & Cloned Phones | 2 | 11-30-2008 13:22 |
Sprint 7700 Flash by MTK | mmcbangla | Chinese Models & Cloned Phones | 2 | 06-27-2008 04:35 |
sprint 7700 flash problem help me | gsm_wrold2007 | Infinity-Box | 3 | 10-04-2007 18:56 |
