Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
09-27-2009, 15:39 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1125708 Status: Offline Thanks Meter: 5 | I9+++ dead after firmware flashing I tried to flash a SciPhone I9+++ and now it’s dead! I’ve bought two of the phones, same manufactor and same firmware. First I read out the firmware of one of them with MTK-Tool 6.1.8 and saved the file as test.bin. Wchina Tool gave the following information about these file: CPU: MT6225 File size: 32 Mb ROM: TG01_PCB01_GPRS_MT6225_S00.TG01_V1_1_0.BIN BUILD: TG01_V1.1.0 PHONE_HW_V1.0 2009/08/12 15:57 build: TG01_V1.1.0 08A TG01 [MCU SW] TG01_V1.1.0 FS(fat) - Start: 0x1C00000, Size: 0x400000 --- Languages -------------- *#0044# |en-US| English *#0351# |pt-PT| Português *#0060# |ms-MY| Bahasa Melayu *#0062# |id-ID| Bahasa Indonesia *#0084# |vi-VN| Ti?ng Vi?t *#0007# |ru-RU| ??????? ???? *#0966# |ar-SA| ??????? *#0066# |th-TH| ??? *#0886# |zh-TW| ???? *#0086# |zh-CN| ???? --- LCD driver -------------- TG01_LCM\lcd.c --- SpeedDial codes --------- *#0000# Auto language *#0044# Set English language *#0886# *#0066# *#0007# Set Russian language *#0351# Set Portuguese language *#0084# *#0062# *#0060# *#0966# *#0086# *#06# Show the IMEI *#3333# *#4444*# Service *#5555# *#33778# Service *#523# *#678# *#876# *#681000# Service *#1234# Set A2DP Mode *#900# BT Power ON *#901# BT Power OFF *#931# *#932# *#933# *#902# *#903# *#3366*# Service As you can see, there was no german language included, that’s why I tried the phone with another firmware. The firmware I used for the flash! Informations from WChina Tool for that firmware: CPU: MT6225 File size: 32 Mb ROM: TG01_PCB01_GPRS_MT6225_S00.TG01_V2_1_0.BIN BUILD: TG01_V2.1.0 PHONE_HW_V2.0 2009/09/05 17:21 build: TG01_V2.1.0 08A TG01 [MCU SW] TG01_V2.1.0 FS(fat) - Start: 0x1C00000, Size: 0x400000 --- Languages -------------- *#0044# |en-US| English *#0033# |fr-FR| Français *#0034# |es-ES| Español *#0351# |pt-PT| Português *#0039# |it-IT| Italiano *#0049# |de-DE| Deutsch *#0060# |ms-MY| Bahasa Melayu *#0062# |id-ID| Bahasa Indonesia *#0084# |vi-VN| Ti?ng Vi?t *#0090# |tr-TR| Türkçe *#0007# |ru-RU| ??????? ???? *#0966# |ar-SA| ??????? *#0066# |th-TH| ??? --- LCD driver -------------- TG01_LCM\lcd.c --- SpeedDial codes --------- *#0000# Auto language *#0044# Set English language *#0034# Set Spanish language *#0033# Set French language *#0049# Set German language *#0039# Set Italian language *#0066# *#0007# Set Russian language *#0351# Set Portuguese language *#0090# *#0084# *#0062# *#0060# *#0966# *#06# Show the IMEI *#3333# *#6666*# Service *#5555# *#33778# Service *#523# *#678# *#876# *#681000# Service *#1234# Set A2DP Mode *#900# BT Power ON *#901# BT Power OFF *#931# *#932# *#933# *#902# *#903# *#3366*# Service After the flash has finished, the phone was dead, nothing I could do any more, only black screen! So I thought the best thing I can do now is to install the firmware from the readback and I did that, but nothing happened, the phone is still dead. I don’t now, what I can do now and I’m looking for somebody who can solve my problems and will help me to find a solution or to unbrick the phone. Hope you can help me! Sorry for my bad english, but it isn't my native language! |
09-27-2009, 20:43 | #2 (permalink) |
Member: 1125708 Status: Offline Thanks Meter: 5 | Did it by myself OK, I just fixed the problem, so for anybody who will have the same problem, I will write, what I've done. I used the format method in MTK-Tool whith manual settings: Beginn-Address: 0x00E00000 Format-Length: 0x00200000 After I formatted the phone with this settings, I used Spiderman Vers. 2.55 and flashed the phone with the firmware, I'd like to use, in this case the one with german language files! And voila, phone still is alive again and german language is now availible for me. Great job, brother Slyme |
10-05-2009, 11:57 | #4 (permalink) |
Member: 1125708 Status: Offline Thanks Meter: 5 | I fixed the problems by the way I wroted on 4 of 5 Sciphone i9+++ with firmware version TG01_V1.1.0 08A Step 1 : Use the MTK-Tool (newest Version), you will find it here in the forum Step 2 : Open MTK, set Baud Rate under Options to 460800, select your COM-Port, click on Format Step 3 : In the new window that will open choose Option "Manual Format FAT" and use as Begin Address: 0x00E00000 and Format Length: 0x00200000 Step 4 : Click on OK (note that there is no battery in your phone until now), put in your battery and power on your phone, using the power on button for 1-2 sec. Step 5: If all settings are good and your flash-cable will work, your phone will be formated very soon Step 6: After formating the phone connect to Spiderman (note that you should use one of the latest versions, those which can decryt firmware files) Step 7: Select COM-Port, set Baud Rate, select NOR-Flash, uncheck V3.840.00 and click on Flash (select firmware-file) Step 8: If flash file and all settings are OK, your new firmware will be installed in a few minutes Step 9: If flash failed, try a lower Baud Rate Step 10: Your done!!! I only have a problem with one of my phones, there won't this solution work, I will get a dead phone after installing the firmware as I described in my first post. When I flash back to original firmware, the phone will work again, but not with the firmware I wish to use. I don't know what's the problem with this phone, cause the others have exactly same firmware and are from the same manufactor and there it will work! Hope this post is useful for somebody, maybe someone knows a solution for the phone on which the flash failed! |
10-10-2009, 18:19 | #5 (permalink) |
Junior Member Join Date: Oct 2008
Member: 877737 Status: Offline Thanks Meter: 0 | can you upload yours flash somewhere? i have simmilar problem .. looks likesoftware into these phones is different phone by phone infinity maybe ill fix CM2.93 v for support this.. but not sure.. All mine phone wake upp. but no one connecting to network |
04-08-2010, 09:09 | #10 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1205216 Status: Offline Thanks Meter: 7 | i9+++ firmware Hi Slyme, good job on fixing your problem! Can you send us the firmware or tell us where to get it? Then we will host it on our site for everyone to download. Thanks! John from Solonomi |
07-20-2010, 11:06 | #11 (permalink) |
No Life Poster Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | iphone Sciphone model: i9+++ after flash dead and i have already read general information plz tell me what i have to do now urgent Hardware version: MT6225, E05 Hardware version: KINGSTAR25_GEMINI_08B_HW Software version: MAUI.08B.W08.52.MP.V Software date: 2006.06.14 Barcode: MT012345678901234567 |
q380 dead after complete flash still dead | bhoybits99 | PadFinder box | 1 | 12-21-2008 11:45 |
Vibra dead after firmware update with phoenix | amras555 | Nokia Base Band 5 ( BB-5 ) | 1 | 05-12-2008 21:01 |
Urgent!!! C2200 dead after firmware flashing!!! | midou01 | VygisToolbox | 5 | 06-27-2006 22:41 |
c55 dead after firmware downgrade help !!! | gonzo | E-Gold Based Phones | 5 | 05-17-2003 20:38 |
3310 dead after wrong flash, after buckup it not turn on????? | Oleg_ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-18-2002 12:35 |
