Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
12-18-2012, 14:07 | #1 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | I9300 FLASH Fail alps gt-i93000 I mistakenly installed a wrong firmware with flash tool v 3.1222.00 phone no power and no usb detected by the PC. I ran a test point and the usb detected but I can not install any firmware report the error attached and the main board mounted model. if someone could help me or suggest me a box to format and reinitializing the phone. thanks to allram test.txt error in flashing , BROM ERROR : S_DA_SETUP_DRAM_FAIL(3002) |
The Following User Says Thank You to orx For This Useful Post: |
01-14-2013, 14:48 | #2 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1867377 Status: Offline Thanks Meter: 0 | I9300 test point Hi I had exactly same issue. I was not able to find test point on this mother board and so I'm not able to connect to pc. Is it possible to have a picture of it. It should be GREAT for me thankes Did you find right ROM .. for it. Thanks again |
01-17-2013, 14:17 | #3 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | Solve : after Test Point; with FlashTool >Format > Format Whole Flash > flashing with correct firmware ( Find FEITENG N9300 ) and rebuid imei's code because will be lost. Pi GU, I send you info. |
05-06-2013, 08:23 | #9 (permalink) |
Member: 1867377 Status: Offline Thanks Meter: 0 | HI, I suggest you to contact [email protected] he solved my same issue |
05-06-2013, 08:53 | #10 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | hi in the meantime send me a picture of the phone and the motherboard and if you have patience in the day i send you picture of Correct T.P. |
05-06-2013, 09:51 | #11 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | Test point here the TP..in case not working use multimeter and search 2,6 / 2.7 v in the various points .. the correct tension is very important for to know test point CLONE.JPG |
06-15-2013, 01:01 | #13 (permalink) | |
Freak Poster Join Date: Aug 2005 Age: 48
Member: 169234 Status: Offline Thanks Meter: 10 | Quote:
06-15-2013, 01:08 | #14 (permalink) | |
