kenxinda m2 flash done but set not on kenxinda m2 flash done but set not on its spd 6620 how to solve in hardware |
writ this file |
knexinda m1 spd flash file kenxinda m1 spd (short mobile).rar - 4shared.com - online file sharing and storage - download |
Kenxinda M1 100% tested solution Quote:
Kenxinda M1 hangs on kenxinda logo, no solution after format, handset still in same condition,only solution is to flash it with this file, |
Kenxinda M2 100% tested solution Quote:
Kenxinda M2 hangs on kenxinda logo, no solution after format, handset still in same condition,only solution is to flash it with this file, |
I Will Try And post result. Quote:
I Will Try And post result.Wait |
Thanks Man Working File 1000000% Knexinda M2 Log Here. Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=13 TXD=23 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 66100000007A6A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. Now Cell Working Perfect. |
cute explain Quote:
Pls Tell In Which CPU Connected |
its working 1000% tested by me thnx bro for this gud file :) |
Kenxinda-m1 flash file cpu;6610/20 flash_gd24q32 Quote:
its not ok file after flash ph lcd 40% is black and 60% ok |
KENXINDA M2 FLASH FILE 100% working KENXINDA M2 SPD661020GD25Q32 - Download - 4shared http://img31.imageshack.us/img31/4946/llj.bmphttp:// PHONE LOCK CODE 2358 |
after write this lcd not work |
