Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
11-16-2009, 17:34 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 417337 Status: Offline Thanks Meter: 0 | M800 watch phone not charge i have a watch phone m800 not charge, if you connect cable on the screen show "USB" and battery look like charging , but after many time when disconect cable , the battery not charged!! same one can help me?? thanks Samuele |
11-17-2009, 08:47 | #2 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1163133 Status: Offline Thanks Meter: 0 | I had the same Problem with my M600 Handyphone. The Unit doesnīt charged even the USB cable was connected. I tryed the second battery (mostly the unit ist delivered with 2 battery packs). And this works. It seems that the first battery pack was faulty ater one year. Try the other battery pack! |
11-17-2009, 15:27 | #4 (permalink) |
Member: 1163133 Status: Offline Thanks Meter: 0 | How do you know that the battery isnīt charged? If the Battery is empty, the watch couldnīt be turned on. If you now connect the watch with the charger, the watch should wake up (sure, it is now supplied by the charger) and work endless. when you now disconnect the charger, the battery should be empty as before (you told so)and the watch should turn off rapidly. If the watch can now be turned on btw. runs for a while, the battery has been charged a little. If not, the battery hasnīt been charged in any way. In this case there could be a failure on the mainboard. How do the pins of the battery connectors look like?Do you have the equipment to measure the charging voltage? |
M800 Watch Phone Icant Boot With Spiderman | gsm4sp | SpiderMan | 11 | 11-22-2010 15:09 |
m800 watch phone not charge | samuele73 | Infinity-Box | 0 | 11-16-2009 17:32 |
here ....M800 watch phone full flash!!! | katocarlos | Infinity-Box | 1 | 11-13-2009 20:11 |
M800 watch phone USB / charger cable | jbes | Chinese Models & Cloned Phones | 0 | 03-04-2009 22:13 |
M800 Watch Phone Icant Boot With Spiderman Need Driver | gsm4sp | Chinese Models & Cloned Phones | 4 | 04-25-2008 12:07 |
