Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
11-10-2009, 14:40 | #1 (permalink) |
Junior Member Join Date: May 2009
Member: 1041889 Status: Offline Thanks Meter: 2 | Message error while flashing with spiderman:"(file) file opend failed" I have a weird problem with spiderman 2.49. I have flashed many phones yet and I met different kind of problems (mainly flash cable problems), but the issue I have now is curious. 1)When I try to flash a I68+, the flashing procedure begins, and then stop after 35 seconds and this message appears "(file) file opend failed", then it stops. 2)When I try to read the firmware, it also stops after 35 seconds, with this message "can't create file for reading". I have tried with several flash cable and several phones, with a lower baudrate but the problem is the same. I guess it has something to do with my computer, but I don't know what. Have you already met that kind of problems?If yes, what did you do to fix it? Thanks a lot for your precious help! |
data error when flash with read file!!! | sirnavid2010 | Infinity-Box | 3 | 12-24-2008 16:20 |
Error while flashing 6680 RM-36 with Phoenix | yoni03 | Nokia Base Band 5 ( BB-5 ) | 1 | 09-22-2006 06:30 |
GX25 error while flashing File System.. | Burnt Cobba | Sharp | 1 | 09-18-2006 08:29 |
