Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 08-15-2010, 07:50   #1 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
Micromax software & Hardware - Repair Area only @gopalhot@
Format Micromax Mobile without pc
Model x1i,x1u,x2i,x211,x332,x4i,x511,x414,x800,x112,x113 & many more
*#8929#
Micromax Mobiles Codes
Model Default Phone
Un-lock Code
Restore Factroy
Setting Code
IMEI Check
Code
Software Version
Check Code
Refresh /
Formatting
X1i 1122 1122 *#06# *#8375# *#8929#
X1u 1122 1122 *#06# *#8375# *#8929#
X211 1122 1122 *#06# *#8375# *#8929#
X332 1122 1122 *#06# *#8375# *#8929#
X4i 1122 1122 *#06# *#8375# *#8929#
X511 1122 1122 *#06# *#8375# *#8929#
X414 1122 1122 *#06# *#8375# *#8929#
X800 1122 1122 *#06# *#8375# *#8929#
X112 1234 1234 *#06# *#8375# *#8929#
X113 1234 1234 *#06# *#8375# *#8929#
X313 N/ A N /A *#06# *#06# *#73738#
X115 0000 0000 *#06# *#18375# or*#67638# N/A
X225 0000 0000 *#06# *#18375# N/A
X250 0000 0000 *#06# *#67638# N/A
X555 1122 1122 *#06# *#8375# N/A
X280 0000 0000 *#06# *#8375# N/A
Q3 1122 1122 *#06# *#84666*# N/A
GC 700 0000 0000 *#06# *#67638# N/A
GC255 0000 0000 *#06# *#6629# N/A
X2i 1122 1122 *#06# *#8375# N/A
X116 0000 0000 *#06# *#67638# N/A1260385400
all download pdf file
post here all Micromax mobile problem and Repair & Solution
The Following 50 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 07:53   #2 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
any solution for micromax X260 lcd light ways?
keypad lights are ok but only display led
Old 08-15-2010, 08:00   #3 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
micromax x 250 battery low shutdoun
The Following 21 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 08:05   #4 (permalink)
R@ZIB-BD's Avatar
Member: 718425
Thanks Meter: 5,873
The Following 8 Users Say Thank You to R@ZIB-BD For This Useful Post:
Old 08-15-2010, 08:20   #5 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
X118 solution for humming & Hissing sound in outgoing
The Following 15 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 08:23   #6 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
all rar and pdf passward is: gopalhot
Old 08-15-2010, 08:41   #7 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
Micromax x1i+ memory card not detect Solution
momery base
123 pins concting to resistors
4 concting to capasitor
so remove this capasitor
The Following 9 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 08:56   #8 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
micro max c2i restore
micro max c2i restore with out pc *#8929#
The Following 3 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 08:59   #9 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
micromax c2i phone is locked
use this code *#8929# formating code
The Following 5 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 09:09   #10 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
unloking micromax 3010p 3010f 3011
2010l 2010
***99*979023#
0302*0#
0303*0#
0304*0#
0305*0#
***99*979023#
0302*0#
0303*0#
0304*0#
0305*0# uloking 2010L 2010
INJOYE
The Following 4 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 09:13   #11 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
micromax x360 hand free problem
make this jumper ur problem will b 100% solved
The Following 19 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 09:17   #12 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
micromax x1i keypad not working
if ur set is direct on when battery inserted and keypad not working
1st open to charging jack
if prolem same
then change to cpu mt6223
ur problem will 100% ok after that
The Following 7 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 09:21   #13 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
micromax BBK Pacetel 308s Dual Display Phone unlocking Code
try this
*#88*1234**##86#0###80###84#0###92#0##
for BBK Pacetel 308s Dual Display Phone unlocking Code....
Thanks in Advance for ur Work
Old 08-15-2010, 09:25   #14 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
all micromax solution UNLOCK file and flasher free @gopalhot@
Micromax tool x 115 x225x250
password: gopalhot
The Following 10 Users Say Thank You to gopalhot For This Useful Post:
Old 08-15-2010, 09:25   #15 (permalink)
R@ZIB-BD's Avatar
Member: 718425
Thanks Meter: 5,873
http://forum.gsmhosting.com/vbb/f457...tions-1071816/
The Following 9 Users Say Thank You to R@ZIB-BD For This Useful Post:
Page generated in 0.28885 seconds with 9 queries
