Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
07-15-2009, 11:39 | #1 (permalink) |
Junior Member Join Date: Sep 2006
Member: 350562 Status: Offline Thanks Meter: 2 | Mini MM96 Iphone problem. Is this a common problem with china phones or do you think it's just my phone and I should get a replacement? Thanks! |
07-17-2009, 13:52 | #2 (permalink) | |
Junior Member Join Date: May 2009
Member: 1037543 Status: Offline Thanks Meter: 1 | Quote:
sorry for my bad english Engineer mode *#20080808* -> AUDIO -> NORMAL -> microphone... level 1-7 set from 160 to 170 (factory 180) or low | |
The Following User Says Thank You to 3473 For This Useful Post: |
07-17-2009, 18:26 | #3 (permalink) |
Member: 350562 Status: Offline Thanks Meter: 2 | Hi thank you very much I tried this: factory defult was 200 for ALL so I changed to: vol0= 160 Vol1=161 vol2=162 vol3=163 vol4=165 vol5=166 vol6=168 vol7=170 I think maybe it is a LITTLE bit better but I can still hear the buzzing on the other end. do you think these values are good? This menu also has "16 level setting": factory defult: Max analog gain = 150 Step = 4 Do you think I should change anything here? Thanks! |
07-17-2009, 19:05 | #4 (permalink) |
Member: 350562 Status: Offline Thanks Meter: 2 | Ok I tried using smaller values which removes the buzzing but also removes my voice. I dont think the mic is the problem because it works fine with a different band (O2). Is there a way to modify the TX signal or filter in engineer mode? There is a RF test tool but I don't understand how to use it. Also network settings but I also don't understand how to use it either. |
The Following User Says Thank You to clit wrangler For This Useful Post: |
mini iphone problem...!!!??? | florent | Chinese Models & Cloned Phones | 14 | 02-16-2010 03:54 |
Mini tv iphone mt6225 | sam93 | Chinese Models & Cloned Phones | 2 | 05-16-2009 14:04 |
mini tv iphone driver french language | sam93 | Chinese Models & Cloned Phones | 2 | 05-16-2009 14:03 |
help mini tv iphone | sam93 | Chinese Models & Cloned Phones | 0 | 05-14-2009 21:56 |
help mini tv iphone | sam93 | Various | 0 | 05-14-2009 12:05 |
