Unlock Server
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 11-09-2012, 14:37   #1 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,820
Thumbs up Mtk Android (Sp flash tool ) tutorial :)
What's needed:
  • USB data cable
  • MediaTek USB VCOM drivers
  • SP Flash Tool ( Latest version SP_Flash_Tool_v3.1224.01)
  • First of all, make sure that you have MediaTek DA USB VCOM drivers installed.
[IMG]http://3.bp.********.com/-1Gxo90bRgIs/T6oifHh6VRI/AAAAAAAABoQ/sXGBr8ZYWNg/s640/drivers.png[/IMG]
Flashing the whole ROM
  • First of all open SP Flash Tool, then click Scatter-loading button to load the correct scatter file
    (MT6575_Android_scatter_emmc.txt or MT6577_Android_scatter_emmc.txt, depending on which phone you have) for your device and ignore any message that may appear.
[IMG]http://3.bp.********.com/-RrYRRBm9s1o/T6pekhu6ReI/AAAAAAAABoc/GJXCY5wRMaQ/s640/sp0.png[/IMG]
  • Turn off your phone, remove the battery and replace it after some seconds (and don't turn on the phone).
  • Press F9 (or hit Download button) and connect your phone into the computer via USB data cable.
    The process will start and a red progress bar will appear.
[IMG]http://1.bp.********.com/-RrASSAGXEGQ/T6perIshToI/AAAAAAAABok/fK97aDwCMFU/s640/sp1.png[/IMG]
[IMG]http://1.bp.********.com/-Svb47VuzFUU/T6pesiuFI4I/AAAAAAAABow/pB9El1k6X-I/s640/sp3.png[/IMG]
  • After the red progress bar is complete, there will appear a purple progress bar.
[IMG]http://3.bp.********.com/-VIozjRN_Kw8/T6petC8e9yI/AAAAAAAABo4/5koWOVnIkWk/s640/sp4.png[/IMG]
  • Right after the purple progress bar is complete, a message will appear underneath it:
    Please insert USB cable in x seconds” and then the download will start right away (you will see the yellow progress bar filling up).
[IMG]http://1.bp.********.com/-AVRfz4ExeFU/T6pet9GOFWI/AAAAAAAABpA/owXnn9uTrUs/s640/sp5.png[/IMG]
  • When the yellow bar is complete, you'll get a popup with a green circle and Download OK message,
    which means that the process has been successfully terminated.
[IMG]http://4.bp.********.com/-IvFvMBgpN3E/T6peuktNpCI/AAAAAAAABpI/bQNPEVJ6FoA/s640/sp6.png[/IMG]
  • You can now safely disconnect your phone and turn it on. The process ends here.
Flashing only part of the ROM
  • In case you want to flash just one part of the ROM, that is also possible. In the shown example, only recovery image will be flashed.
    Deselect all parts except the one(s) you want to flash and then press F9 (or hit Download button).
[IMG]http://3.bp.********.com/-vZsQrYyNFlA/T6pevV8ptjI/AAAAAAAABpU/HGjxFwDowL4/s640/sp7.png[/IMG]
  • The tool will immediately show a warning because not all parts are selected, but you should continue anyway. Safely press Yes to continue.
[IMG]http://4.bp.********.com/-tda8yHWu76Y/T6pexQF9pUI/AAAAAAAABpc/LC8E6ZAJlvQ/s640/sp8.png[/IMG]
  • The download of the chosen partition image will start and after the yellow bar is complete, the popup with the green circle should appear.
[IMG]http://1.bp.********.com/-PCFU9ORmLEI/T6peyG1GoyI/AAAAAAAABpg/6v774s9ZAA4/s640/sp9.png[/IMG]
[IMG]http://3.bp.********.com/-CkVJDGOrIr8/T6per4bSQCI/AAAAAAAABoo/KsHZ1_Ywq-o/s640/sp10.png[/IMG]
  • Please note that, even though it isn't mandatory to select it on the list of images to flash,
    preloader file must be present in the same folder as the other partition(s) that you want to flash, or else phone will not be able to enter into download mode.
Attention: Please follow the instructions carefully. I will not take any responsibility on whatever may happen with your phone.
Very important warning: Always make sure that you trust the sources of the ROM you download and know that it is meant for your phone.
After flashing a wrong preloader, your phone will be completely dead (can't be powered on, it will not charge and won't be detected anymore by the computer) and there is no way to recover it.
The Following 7 Users Say Thank You to .::AZEEM::. For This Useful Post:
Old 11-09-2012, 15:00   #2 (permalink)
ashamsu's Avatar
Member: 376471
Sonork: 100.1608095
Thanks Meter: 88
Dear Member........
here is your link............... SP_Flash_Tool_v3.1224.01.rar
Old 11-09-2012, 15:04   #3 (permalink)
.::V!K@$H::.'s Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 342
it"s old story..man...........
Old 11-09-2012, 15:09   #4 (permalink)
ashamsu's Avatar
Member: 376471
Sonork: 100.1608095
Thanks Meter: 88
Dear Member......
here is another link... i got it from
Tutorial: Install ClockWorkMod (CWM) Recovery On Noir A8 | Ehtisham Siddiqui
Old 11-09-2012, 15:12   #5 (permalink)
ashamsu's Avatar
Member: 376471
Sonork: 100.1608095
Thanks Meter: 88
Dear Member........
then why Product Supporter posting it today...
Do you have any other thread in this forum, as posted in this thread...
Old 11-09-2012, 15:13   #6 (permalink)
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 342
Originally Posted by ashamsu View Post
Dear Member........
no maybe no have tread in forum
but i have.....
i don"t no
maybe for new users......
Old 11-09-2012, 15:45   #7 (permalink)
ashamsu's Avatar
Member: 376471
Sonork: 100.1608095
Thanks Meter: 88
but i have.....
i don"t no
Dear Member.......
if you keep that it for yourself, it is useless..........
Dont blame on others...........
Old 11-09-2012, 20:04   #8 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 840
Thanks to .::AZEEM::. for this tutorial Looking this tutorial will be very usefull for everyone so i converted first post to pdf to save it in pc.
Here is the PDF file link
Good Luck!
The Following User Says Thank You to >>PakFones<< For This Useful Post:
Old 11-09-2012, 21:09   #9 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 5,099
MT6575_Android_scatter_emmc.txt - 4shared.com - document sharing - download - Maurizio Lipari
MT6577_Android_scatter_emmc.txt - 4shared.com - document sharing - download
The Following User Says Thank You to Umesh_Arora For This Useful Post:
Old 11-10-2012, 05:02   #10 (permalink)
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,820
but i have.....
i don"t no
Old story ?
Can u show me thread Sp tool tutorial ?
Yes i know Ur Too intelligent but some time every one do some small mistakes and also many more users don't know how to use
Note :- I'm trying to help my Gsm friends Not doing job Work or any advancement
If u help Some One Some other time when u Struggle he will be help us
Helping Nature is not a bad thing
The Following 2 Users Say Thank You to .::AZEEM::. For This Useful Post:
Old 11-10-2012, 08:10   #11 (permalink)
ashamsu's Avatar
Member: 376471
Sonork: 100.1608095
Thanks Meter: 88
Dear Member.......
links are not valid.............
Old 11-11-2012, 05:55   #12 (permalink)
wiro_cool's Avatar
Member: 820104
Sonork: 100.1606814
Thanks Meter: 98
Talking
Dear Member.......
Link is Valid and Tested By Me,,,,
Old 12-14-2012, 17:46   #13 (permalink)
Member: 361094
Sonork: 100.1597521
Thanks Meter: 94
Question
Originally Posted by .::AZEEM::. View Post
What's needed:
  • USB data cable
    Please insert USB cable in x seconds and then the download will start right away (you will see the yellow progress bar filling up).
thanks for ur link brother it awesome please if u have qmobile noil a8 full backup please share here
mt6577
android 4.0.4
sw ver :alps.ics2.6577.sp.v1
thanks advance
Old 12-18-2012, 07:24   #14 (permalink)
Member: 361094
Sonork: 100.1597521
Thanks Meter: 94
i must need rom file for mt6577 a8 qmobile if any have please share here thanks advance....
Old 12-18-2012, 07:36   #15 (permalink)
Member: 361094
Sonork: 100.1597521
Thanks Meter: 94
Question
Dear Member......
bro if u have backup for qmobile a8 mt6577 please share here i must need for dead set thanks........?
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.48818 seconds with 7 queries
