Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
03-05-2009, 06:20 | #2 (permalink) | |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | Quote:
try this code- *#3424# *#987*99# *#19740829# *#2004*#2004# *727793# also i do skywork by cpf-box, for me its working good, plz try. Last edited by tkowsar; 03-05-2009 at 07:00. | |
04-03-2009, 13:43 | #5 (permalink) |
Product Manager Join Date: Sep 2007 Location: Malaysia, Dubai, China.
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | back side label "cect jr777i"(like n70 copy) front side label "Diamond" Cpu type "skyworks" it's 2*5 pin jeck............ RX=10,TX=5(searched by pinfinder) Problem - Restart with sim Now give the right solution...... |
04-03-2009, 16:30 | #6 (permalink) | |
first try to initializing/restore/write API (must backup first you old/current API) with a good api file, if still same, next try to flash | |
04-04-2009, 14:02 | #7 (permalink) | |
Member: 599306 Status: Offline Sonork: 100.1578386 Thanks Meter: 5,136 | Quote:
Current Port:COM33 Waiting for phone's response,press the Power on the phone. Boot downloading...44% Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 >>Communication failed! i have 2 phones 1 is on usercode and second is on silent mode when i select ring mode it automatacly revars on silent mode please post its solution thanx in advance | |
04-05-2009, 06:13 | #8 (permalink) |
Member: 233205 Status: Offline Thanks Meter: 5,014 | which device u use? when read or write flash file, press and hold power button till start read. that means, when soft tell you to press power button for phone boot, press and hold, now its show you flash size, bootloder, hardware info etc than its start read flash 1%...50%...100% than when device start to read or show start 1% read, this time release power button or some seconds before. try plz. |
04-10-2009, 13:33 | #9 (permalink) | |
Current Port:COM33 Waiting for phone's response,press the Power on the phone. Boot downloading...44% Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 Communication failed! Waiting for phone's response,press the Power on the phone... Boot download finished! Flash Reading: Start Address: 0x1000000 Read Length: 0x1000000 >>Communication failed! | |
04-10-2009, 14:23 | #10 (permalink) |
Member: 233205 Status: Offline Thanks Meter: 5,014 | are you try with battery and power supply both? if cable have vcc pin, not need any extra power to give on batt conn. if all is ok, than now check phone hardware. |
reset usercode m8910 ok with z3x | sirnavid2010 | Z3X-Team Products | 0 | 03-29-2010 12:05 |
pls help for nokia n70 | jabed_net | Nokia Base Band 5 ( BB-5 ) | 8 | 02-04-2010 16:50 |
help reset samsung F519 usercode | davilixian | Various CDMA/TDMA Cell Phones | 2 | 02-07-2009 15:04 |
Help! Reset Lg Kg300 Usercode Using Infinity | firman al ulum | Infinity-Box | 6 | 09-27-2007 23:35 |
k800 user code how to reset? help pls (flash mcu+fs_customize) will reset usercode | beans | Cruiser Suite | 5 | 02-03-2007 00:31 |
