Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
12-12-2009, 08:22 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1181851 Status: Offline Thanks Meter: 0 | need help: China W9630 "not allowed to dial" I have a China W9630. It is always in wlan only mode. i cannot change the preferred mode. And when i try to dial, it says "not allowed to dial". Anyone knows the problem and solution? Thanks in advance! |
04-12-2010, 11:43 | #6 (permalink) |
Junior Member Join Date: Oct 2006
Member: 371836 Status: Offline Thanks Meter: 2 | Hello everybody, after playing arround for a while, collecting a lot of other information from the net, I got the problem solved with my phone: 01. Make sure two SIMs are online with good coverage, WLAN switched off. 02. Press the "call"-button and type in *#9646633# 03. The phone shows "Engineer mode" with a menu of 10 different items. 04. Go to No. 10 "RF test tool", using the up/down button at the left side of the mobile. 05. Choose "GSM" 06. A message shows up "Wifi....blabla", just confirm with OK 07. Choose "Power Scan" 08. Select your local GSM frequency (in my case DSC 1800 for Germany) and press OK. 09. The mobile will freeze now, because its adjusting itself. Leave it like this for about 2-3 minutes and wait !!! 10. Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!! 11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display. 12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup" 13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only" 14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds. 15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection. 16. Get back to main menu, switch off and restart the mobile |
04-12-2010, 13:41 | #7 (permalink) |
Member: 371836 Status: Offline Thanks Meter: 2 | this will surely work 1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive(can take 3 to 15 min) press the end button (red one) phones with one middle button use that one phone will go off turn on phone and it will be reset to flight mode.... (you can try to make call to verify,phone wil say cannot make call,not, not allowed to dial like before) go to settings and network setup,sim1 network setup,prefered mode and select gsm prefered...(phone will now change mode unlike before saying unfinnished) try the phone to make a call (should be no prob now) not finnished though .... go into settings again select restore factory settings (password 1122) wait for phone to restart...now its all done .....now you can change your tones and turn wlan on etc do not for any reason select wlan only or gsm only again... |
12-10-2010, 20:19 | #8 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Quote:
"NOT ALLOWED TO DIAL" E71 Made in China | babikubi | Chinese Models & Cloned Phones | 5 | 07-10-2010 13:59 |
need help: how to enter the code after entering it wrong 10 times | RotKT | BlackBerry (RIM) | 13 | 03-11-2009 00:38 |
7650 - "Not allowed!" | Ammonit | Phone Unlocking Codes & Maps | 2 | 02-15-2003 21:44 |
Need Help: How To Repair "Contact Services" on 3350 | rinvend | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 06-18-2002 14:53 |
need help: try to repair contact service | Vigilius | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-12-2002 09:25 |
